Force Sensitive Resistor OverLoad
Napsal: 08 zář 2017, 11:01
I've got just a simple question. What happens when I overload FSR. Let's say that it's got force sensitive range between 100g and 10 000g. What would happen if I'd create pressure about 100kg? I see that resistance is decreasing with bigger pressure. Will there be almost 0 ohm resistance? If so, can this FSR survive this overload? Has somebody test that?
Thank you for any answer.
