Force Sensitive Resistor OverLoad
CMAZE
Příspěvek od CMAZE » 08 zář 2017, 11:01
I've got just a simple question. What happens when I overload FSR. Let's say that it's got force sensitive range between 100g and 10 000g. What would happen if I'd create pressure about 100kg? I see that resistance is decreasing with bigger pressure. Will there be almost 0 ohm resistance? If so, can this FSR survive this overload? Has somebody test that?
Thank you for any answer.
Wojta
Re: Force Sensitive Resistor OverLoad
Příspěvek od Wojta » 08 zář 2017, 17:25
Man you are copy pasting that all over the internet. I found like 10 threads already that you posted with the same content on many other forums so there is no real point to us responding. This question is probably answered many times by now. Sure, if someone has to say something interesting about it, go ahead, Im just pointing to the fact that you have got many answers already.
Cheers!
