Neznámy display
Kony
Neznámy display
Příspěvek od Kony » 16 čer 2020, 17:16
Ahoj, objednal jsem z Ali display...
pomoci arduina Mega jsem nechal vypsat jeho parametry, sice na začátku výpisu to vypisuje že je to display 2,4" ale je to správně 3.5"
6:48:54.529 -> TFT LCD test
16:48:54.575 -> Using Adafruit 2.4" TFT Breakout Board Pinout
16:48:54.629 -> TFT size is 320x480
16:51:35.011 -> Read Registers on MCUFRIEND UNO shield
16:51:35.062 -> controllers either read as single 16-bit
16:51:35.108 -> e.g. the ID is at readReg(0)
16:51:35.162 -> or as a sequence of 8-bit values
16:51:35.162 -> in special locations (first is dummy)
16:51:35.209 ->
16:51:35.209 -> reg(0x0000) 00 00 ID: ILI9320, ILI9325, ILI9335, ...
16:51:35.262 -> reg(0x0004) 00 54 80 66 Manufacturer ID
16:51:35.309 -> reg(0x0009) 00 00 61 00 00 Status Register
16:51:35.385 -> reg(0x000A) 00 08 Get Power Mode
16:51:35.432 -> reg(0x000C) 00 66 Get Pixel Format
16:51:35.432 -> reg(0x0061) 00 00 RDID1 HX8347-G
16:51:35.478 -> reg(0x0062) 00 00 RDID2 HX8347-G
16:51:35.525 -> reg(0x0063) 00 00 RDID3 HX8347-G
16:51:35.562 -> reg(0x0064) 00 00 RDID1 HX8347-A
16:51:35.609 -> reg(0x0065) 00 00 RDID2 HX8347-A
16:51:35.609 -> reg(0x0066) 00 00 RDID3 HX8347-A
16:51:35.662 -> reg(0x0067) 00 00 RDID Himax HX8347-A
16:51:35.709 -> reg(0x0070) 00 00 Panel Himax HX8347-A
16:51:35.762 -> reg(0x00A1) 00 93 30 93 30 RD_DDB SSD1963
16:51:35.809 -> reg(0x00B0) 00 00 RGB Interface Signal Control
16:51:35.862 -> reg(0x00B4) 00 00 Inversion Control
16:51:35.862 -> reg(0x00B6) 00 02 02 3B 3B Display Control
16:51:35.902 -> reg(0x00B7) 00 06 Entry Mode Set
16:51:35.962 -> reg(0x00BF) 00 00 00 00 00 00 ILI9481, HX8357-B
16:51:36.009 -> reg(0x00C0) 00 0E 0E 0E 0E 0E 0E 0E 0E Panel Control
16:51:36.063 -> reg(0x00C8) 00 00 00 00 00 00 00 00 00 00 00 00 00 GAMMA
16:51:36.109 -> reg(0x00CC) 00 04 Panel Control
16:51:36.163 -> reg(0x00D0) 00 00 00 Power Control
16:51:36.210 -> reg(0x00D2) 00 00 00 00 00 NVM Read
16:51:36.264 -> reg(0x00D3) 00 00 94 86 ILI9341, ILI9488
16:51:36.264 -> reg(0x00D4) 00 00 00 00 Novatek ID
16:51:36.310 -> reg(0x00DA) 00 54 RDID1
16:51:36.348 -> reg(0x00DB) 00 80 RDID2
16:51:36.348 -> reg(0x00DC) 00 66 RDID3
16:51:36.402 -> reg(0x00E0) 00 00 0A 07 0F 07 0E 4A 67 58 01 05 05 38 26 0E GAMMA-P
16:51:36.463 -> reg(0x00E1) 00 0E 1A 09 0D 0B 0F 70 87 79 0D 07 0D 06 08 03 GAMMA-N
16:51:36.564 -> reg(0x00EF) 00 80 00 10 60 40 ILI9327
16:51:36.564 -> reg(0x00F2) 00 18 A3 12 02 B2 12 FF 10 00 00 00 Adjust Control 2
16:51:36.664 -> reg(0x00F6) 00 54 80 66 Interface Control
jediný co mi funguje s tímto displeyem je :
// IMPORTANT: Adafruit_TFTLCD LIBRARY MUST BE SPECIFICALLY
// CONFIGURED FOR EITHER THE TFT SHIELD OR THE BREAKOUT BOARD.
// SEE RELEVANT COMMENTS IN Adafruit_TFTLCD.h FOR SETUP.
//Technical support:goodtft@163.com
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_TFTLCD.h> // Hardware-specific library
// The control pins for the LCD can be assigned to any digital or
// analog pins...but we'll use the analog pins as this allows us to
// double up the pins with the touch screen (see the TFT paint example).
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
// When using the BREAKOUT BOARD only, use these 8 data lines to the LCD:
// For the Arduino Uno, Duemilanove, Diecimila, etc.:
// D0 connects to digital pin 8 (Notice these are
// D1 connects to digital pin 9 NOT in order!)
// D2 connects to digital pin 2
// D3 connects to digital pin 3
// D4 connects to digital pin 4
// D5 connects to digital pin 5
// D6 connects to digital pin 6
// D7 connects to digital pin 7
// For the Arduino Mega, use digital pins 22 through 29
// (on the 2-row header at the end of the board).
// Assign human-readable names to some common 16-bit color values:
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
// If using the shield, all control and data lines are fixed, and
// a simpler declaration can optionally be used:
// Adafruit_TFTLCD tft;
void setup(void) {
Serial.println(F("TFT LCD test"));
#ifdef USE_ADAFRUIT_SHIELD_PINOUT
Serial.println(F("Using Adafruit 2.4\" TFT Arduino Shield Pinout"));
#else
Serial.println(F("Using Adafruit 2.4\" TFT Breakout Board Pinout"));
#endif
Serial.print("TFT size is "); Serial.print(tft.width()); Serial.print("x"); Serial.println(tft.height());
tft.reset();
tft.begin(0x9481);
void loop(void) {
Serial.println(F("I'm know"));
tft.fillScreen(BLACK);
unsigned long start = micros();
tft.setCursor(0, 0);
tft.setTextColor(RED); tft.setTextSize(1);
tft.println("Hello World!");
tft.println(01234.56789);
tft.println(0xDEADBEEF, HEX);
tft.println();
tft.println();
tft.setTextColor(GREEN); tft.setTextSize(2);
tft.println();
tft.println();
tft.setTextColor(BLUE); tft.setTextSize(3);
tft.setTextColor(WHITE); tft.setTextSize(4);
tft.println("Hello!");
tft.setTextColor(YELLOW); tft.setTextSize(5);
tft.setTextColor(RED); tft.setTextSize(6);
tft.println();
tft.println();
tft.println();
tft.setTextSize(5);
tft.println("Groop");
tft.setTextSize(2);
tft.println("I implore thee,");
tft.setTextSize(1);
tft.println("my foonting turlingdromes.");
tft.println("And hooptiously drangle me");
tft.println("with crinkly bindlewurdles,");
tft.println("Or I will rend thee");
tft.println("in the gobberwarts");
tft.println("with my blurglecruncheon,");
tft.println("see if I don't!");*/
delay(1000);delay(1000);delay(1000);delay(1000);delay(1000);
ale je to vše zrcadlově otočené
Ani zaboha nemůžu přijít na to jak to oživit....
a když tam změním na
tft.begin(0x9341);
tak je to sice dobre, ale hrozne ten display problikava
Re: Neznámy display
Příspěvek od martinius96 » 16 čer 2020, 17:28
Ja ten displej mám.. Asi už 3 roky.. Je to MCU Friend 3.5'' TFT LCD displej, kompatibilný pre všetky R3 dosky (Uno, Mega).
Avšak čo si pamätám, tak mal radič ILI 9488. Mal som ho aj s dotykom. Avšak ten displej mi toho času fungoval invertovane.. Klikol som vľavo dole a bralo ho dotyk vpravo hore. Skúšal som to aj softvérovo preklápať, avšak nepodarilo sa mi to. Po pár neúspešných testoch som ho odložil do šuflíka..
Kony
Re: Neznámy display
Příspěvek od Kony » 16 čer 2020, 17:40
no tak to je super.... a co doporučuješ za display ??? samozřejmě dotykovy
Kony
Re: Neznámy display
Příspěvek od Kony » 16 čer 2020, 18:04
Co tady toto ???
[Kč313.87 32% OFF]3,2 palcový ILI9341 TFT dotykový panel LCD displeje Geekcreit pro Arduino - výrobky, které pracují s oficiálními deskami Arduino Module Board from Electronic Components & Supplies on banggood.com https://banggood.app.link/jwu3HtYTm7
Nebo toto
US $11.22 15% Off | 3.95"/4.0" inch 320*480 ST7796S TFT Color LCD Display Module Screen with Touch Panel For Arduino UNO Mega2560 8/16 Bit
https://a.aliexpress.com/_B0bNoi
Nebo
US $7.26 13% Off | 3.5" 3.5 inch 480x320 TFT LCD Touch Screen Module ILI9486 LCD Display for Arduino UNO MEGA2560 Board with/Without Touch Panel
https://a.aliexpress.com/_B1UiaS
Nebo
US $8.32 14% Off | TZT 3.5" 3.5 inch 480x320 TFT LCD Touch Screen Module ILI9486 LCD Display for Arduino UNO MEGA2560 Board Without Touch Panel
https://a.aliexpress.com/_BTuQzo
US $32.03 11% Off | New 7" inch TFT LCD module 800x480 SSD1963 Touch PWM For Arduino AVR STM32 ARM 800*480 800 480 Digital Control Board
https://a.aliexpress.com/_B1gykW
Proste cim vetsi tim lepsi, bude se pres to ovladat komplet domacnost(svetla,klima,cidla atd)
Re: Neznámy display
Příspěvek od pavel1tu » 16 čer 2020, 20:16
Pokud domácnost, tak stejně dojdeš jako já jen ke 2 řešením:
- velký Nextion - ušetří ti spoustu kodu v Arduinu, už ani do DUE se nevejdeme (tzv. malé řešení)
- klasický tablet a zobrazovat WWW stránku, vše se seběhne v Mini/Mikro PC, kde běží server. Vše osotatní mu posílá data a bere data od něj, on vše zpracuje - po LAN nebo 433/866MHz.
Kony
Re: Neznámy display
Příspěvek od Kony » 17 čer 2020, 07:32
No na tabletu jsem taky premyslel, ale tam nevim jak docilit toho, aby pri zapnuti se hned zobrazila www stranka pres celou obrazovku... mam tady 7" tablet s androidem...
Bylo by to asi uplne nejlepsi, protoze na web strance se da zobrazit uplne vse, vcetne predpovedi pocasi atd, ale stve me to, ze se musi tuknout, odemknout, a pustit prohlizec a jeste to, ze to neni komplet pres celou obrazovku.
mart-in
Re: Neznámy display
Příspěvek od mart-in » 17 čer 2020, 07:51
Kony píše:
17 čer 2020, 07:32
Ahoj, přesně na toto jsou různé apky, hledal bych na googlu něco jako "Android kiosk mode" např. aplikace GoKiosk :)
Kony
Re: Neznámy display
Příspěvek od Kony » 17 čer 2020, 08:27
Super díky moc
Kony
Re: Neznámy display
Příspěvek od Kony » 17 čer 2020, 14:29
Tak jsem asi nasel co mi nejvic vyhovuje, ale vsechny aplikace jsou s mesicnim placenim....
nejvic me vyhovuje "Surefox",
Neznate nekdo nejaky bud free a nebo s jednou platbou a bude to placena verze ??
Kony
Re: Neznámy display
Příspěvek od Kony » 19 bře 2021, 08:24
Ahoj....
takze displey
https://www.aliexpress.com/snapshot/0.h ... 3037936383
uz ani nepotrebuji dotyk :)) jen aby to zobrazovalo tak jak ma... Neresil nekdo prosim ???
