client.println("GET http://konycz.eu/doma/test/cas.php");
client.println(" HTTP/1.0");
Co tohle?
client.println("GET /doma/test/cas.php HTTP/1.1");
client.println("Host: konycz.eu");
11:36:42.643 -> Cas : HTTP/1.1 200 OK
11:36:42.643 -> _________________________
11:36:48.639 -> Cas : HTTP/1.1 200 OK
11:36:48.639 -> _________________________
11:36:54.629 -> Cas : HTTP/1.1 200 OK
11:36:54.629 -> _________________________
11:37:00.670 -> Cas : HTTP/1.1 200 OK
11:37:00.670 -> _________________________
11:37:06.663 -> Cas : HTTP/1.1 200 OK
11:37:06.663 -> _________________________
#include <ESP8266WiFi.h>
// Nazev Wi-Fi site, do ktere se mam pripojit
const char* ssid = "Kony";
// Heslo Wi-Fi site, do ktere se mam pripojit
const char* password = "heslowifi";
char server[] = "192.168.1.250"; //URL adresa serveru
WiFiClient client;
unsigned long cas = 0;
String cas_aktualni;
Serial.println();
Serial.print("Pripojuji k ");
Serial.println(ssid);
WiFi.begin(ssid, password);
// Dokud nejsem pripojeny k Wi-Fi,zapisuj do seriove linky tecky progressbaru
delay(100);
Serial.print(".");
// Jsem pripojeny k Wi-Fi a mohu pokracovat
Serial.println();
Serial.println("WiFi pripojena!");
// Napis IP adresu, kterou mikropocitac dostal
Serial.print("Pouzij k pripojeni tuto adresu: ");
Serial.print("http://");
void hodiny() {
if (millis() - cas >= 6000 || cas == 0) {
cas = millis();
if (client.connect(server, 80)) { //starts client connection, checks for connection
client.println("Host: 192.168.1.250");
client.println("Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8");
client.println();
while (client.connected()) {
String line = client.readStringUntil('\n');
Serial.println(line); //ak chceme vypísať HTTP header
if (line == "\r") {
break;
// Serial.println("Nacitany payload response: Cas - ");
// Serial.println(line); //odpoveď webservera - naše dáta
cas_aktualni = line;
else {
Serial.println("Pripojenie na webserver sa nepodarilo");
client.stop();
Serial.print("Cas : ");
Serial.println(cas_aktualni);
hodiny();
Serial.println("_________________________");
delay(5000);
}Kód: Vybrat vše
String headers = client.readStringUntil('\r');
String data = client.readStringUntil('\r');
Serial.print("Headers: ");
Serial.println(headers);
Serial.print("Data: ");
Serial.println(data);
WiFiClient client;
String headers1;
String data;
Serial.println();
delay(100);
Serial.print(".");
Serial.println();
void hodiny() {
cas = millis();
client.println();
headers1 = client.readStringUntil('\r');
Serial.println(headers1);
// cas_aktualni = line;
else {
client.stop();
hodiny();
delay(5000);
}Kód: Vybrat vše
20:16:55.352 -> Headers:
20:16:55.352 -> Data:
20:16:55.352 -> Cas :
20:16:55.352 -> _________________________
Funguje mi to úplne bez problému. Použil som example kód pre HTTP request z Githubu (Arduino Core pre ESP8266).Kony píše: ↑29 říj 2021, 15:54Tak taky ne, stejny vysledek
Schvalne muzes vyzkousetKód: Vybrat vše
http://213.211.34.227/testik/cas.php
//Pripojenie na webserver a nacitanie HTTP hlavicky, Payloadu (text / HTML / JSON...)
const char* ssid = "SSID_NAME"; //SSID WiFi siete
const char* password = "SSID_PASSWORD"; //HESLO WiFi siete
const char* host = "213.211.34.227"; //IP adresa, alebo domena webservera
const int httpPort = 80;
WiFiClient client; //pre HTTP
void hodiny();
Serial.begin(115200); //rychlost seriovej linky
Serial.println();
Serial.print(F("Pripajanie na WiFi siet: "));
Serial.print(F("."));
Serial.println(F(""));
Serial.println(F("Wifi pripojene"));
Serial.print(F("Pridelena IP adresa z DHCP: "));
hodiny();
void hodiny() {
client.stop();
if (client.connect(host, httpPort)) {
String url = F("/testik/cas.php");
Serial.println(F("Pripojenie uspesne, nacitavam odpoved servera"));
client.print(String(F("GET ")) + url + F(" HTTP/1.0\r\n") + F("Host: ") + host + F("\r\n") + F("User-Agent: NodeMCU\r\n") + F("Connection: close\r\n\r\n"));
String line = client.readStringUntil('\n'); //HTTP HEADER
if (line == F("\r")) {
break;
String line = client.readString(); //PAYLOAD
} else if (!client.connect(host, httpPort)) {
Serial.println(F("Nepodarilo sa pripojit na webserver"));
