visk52
Příspěvek od visk52 » 05 črc 2021, 19:27
Zdravím
Potřeboval bych vybrat z kódu https://www.gsampallo.com/2020/04/20/su ... esp32-cam/ část která udělá fotku a nechá jí bufferu? díky
SkullKeep
Příspěvek od SkullKeep » 05 črc 2021, 20:15
Jestli jsem se dobře díval tak jsem z toho vybral část kódu:
#include "esp_camera.h"
// Pin definition for CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
camera_config_t config;
initCamera();
void initCamera() {
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  if(psramFound()){
    config.frame_size = FRAMESIZE_UXGA;//FRAMESIZE_UXGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
    config.jpeg_quality = 10;
    config.fb_count = 2;
  } else {
    config.jpeg_quality = 12;
    config.fb_count = 1;
  // Init Camera
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  takePhoto();
  delay(60000);
void takePhoto() {
     camera_fb_t * fb = NULL;
   // Take Picture with Camera
  fb = esp_camera_fb_get();
  if(!fb) {
    Serial.println("Camera capture failed");
    return;
  esp_camera_fb_return(fb);
Snad jsem se trefil. :idea:
visk52
Příspěvek od visk52 » 06 črc 2021, 17:23
  Serial.begin(115200);
initCamera();
void initCamera() {
  if(psramFound()){
  } else {
  // Init Camera
    return;
  takePhoto();
 //Serial.print(fb->len);
  delay(60000);
void takePhoto() {
  if(!fb) {
    return;
v seriovém monitoru se vypisuje toto :o díky
SkullKeep
Příspěvek od SkullKeep » 06 črc 2021, 18:39
Co zkusit zmenšit rozlišení kamery.
a
na
config.frame_size = FRAMESIZE_VGA;//FRAMESIZE_UXGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
a
Podle mne jde i o to jestli máš stejný noul nebo jinačí verzi. A taky jde o to jestli máš na HDD knihovnu esp_camera.h.
Nebo jestli jsem neudělal chybu při zkrácení a nechybí tam tyto řádky:
#include "driver/rtc_io.h"
#include "time.h"
těsně po #include "esp_camera.h". Jinak s toutu funkcí nemám vlastní zkušenosti a jenom jsem to z toho vytáhl.
visk52
Příspěvek od visk52 » 06 črc 2021, 20:19
Abych to vysvětlil ten program co mám výše ten odkaz tak jsem si to upravil na mou WiFI a FTP server a mě to funguje to jsem dělal ten projekt před časem, ale když ten program začnu upravovat - mažu WIFI a tak dále o čem jsem přesvětčen že to nesouvisí abych jen zůstalo to co potřebuji tak to hází chyby, modul ESP32 CAM na čem to zkouším tak mám prověřen že tam není chyba je to pro mne záhada :shock: díky
visk52
Příspěvek od visk52 » 08 črc 2021, 17:51
Já už jsem s toho s toho zoufalý a nevím si rady můžete mi s tohoto zdrojáku vytáhnout jen tu část která udělá snímek protože tento celý program na tom modulu funguje díky
 * ESP32cam_ftp
 * Blog: http://www.gsampallo.com/blog/?p=686
 * Twitter: @gsampallo.com
#include "soc/soc.h"           // Disable brownour problems
#include "soc/rtc_cntl_reg.h"  // Disable brownour problems
#include <WiFi.h>
#include <WiFiClient.h>
#include "ESP32_FTPClient.h"
#include <NTPClient.h> //For request date and time
#include <WiFiUdp.h>
#include "time.h"
unsigned long TimeStamp;
const int interval = 1;// minuty
const unsigned long SamplingTime = 60000 * interval;
char ftp_server[] = "xxxxxxxxxxxxxxxx";
char ftp_user[] = "xxxxxxxxxxxxxxxx";
char ftp_pass[] = "xxxxxxxx";
char ftp_path[] = "/xxxxxxxxxxxxxxxxx";
const char* WIFI_SSID = "xxxxxxxx";
const char* WIFI_PASS = "xxxxxxx";
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP, "pool.ntp.org", (3600), 60000);
ESP32_FTPClient ftp (ftp_server,ftp_user,ftp_pass, 5000, 2);
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
  WiFi.begin(WIFI_SSID, WIFI_PASS);
  Serial.println("Connecting Wifi...");
      delay(500);
      Serial.println("Connecting to WiFi..");
  Serial.println("IP address: ");
  initCamera();
  timeClient.begin();
  timeClient.update();
  Serial.println(timeClient.getFormattedTime());
  ftp.OpenConnection();
 // if ((millis() > SamplingTime) && ((millis() - SamplingTime) > TimeStamp) && (WiFi.status() == WL_CONNECTED)) {
  takePhoto();
void initCamera() {
  if(psramFound()){
  } else {
  // Init Camera
    return;
void takePhoto() {
  Serial.print("Velikost obrazu: ");
  Serial.println(fb->len);
  if(!fb) {
    return;
   * Upload to ftp server
  ftp.ChangeWorkDir(ftp_path);
  ftp.InitFile("Type I");
  String nombreArchivo = "picture.jpg";
 // timeClient.getFormattedTime()+".jpg"; // AAAAMMDD_HHMMSS.jpg
  Serial.println("Nahravani  "+nombreArchivo);
  int str_len = nombreArchivo.length() + 1;
  char char_array[str_len];
  nombreArchivo.toCharArray(char_array, str_len);
  ftp.NewFile(char_array);
  ftp.WriteData( fb->buf, fb->len );
  ftp.CloseFile();
   * Free
SkullKeep
Příspěvek od SkullKeep » 08 črc 2021, 18:53
Zkus toto jestli bude fungovat:
  initCamera();
  takePhoto();
void initCamera() {
  if(psramFound()){
  } else {
  // Init Camera
    return;
void takePhoto() {
  if(!fb) {
    return;
   * Free buffer cam
visk52
Příspěvek od visk52 » 08 črc 2021, 19:21
Už to nepadá ale nevypisuje se na seriový monitor nic viz
jak by to mělo dělat ;) díky
edit beru zpět už to funguje chybělo to to
jsi jednička palec nahoru
visk52
Příspěvek od visk52 » 08 črc 2021, 20:17
Tak je to díky
SkullKeep
Příspěvek od SkullKeep » 09 črc 2021, 10:50
Rád jsem pomohl. Kdyby bylo něco podobného třeba jsem tu na fóru. :idea: :P
