problém s webservrem
wes server
Příspěvek od wes server » 08 kvě 2018, 01:03
Napsal jsem a částečně složil tento kod:
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <FS.h>
const char* ssid = "---------";
const char* password = "*******";
ESP8266WebServer server(80);
File fsUploadFile;
String XML;
String zprava1="test1";
String zprava2="test2";
String ip1;
String ip2;
String ipa;
void nenalezeno(){
  File file = SPIFFS.open("/nenalezeno.htm", "r");
   size_t sent = server.streamFile(file, "text/html");
   file.close();
void printhtml(){
  WiFiClient client = server.available();
 if(server.arg("stat")!=""){
  zaips(client.remoteIP);}
   File file = SPIFFS.open("/index.htm", "r");
   file.close();
  void js(){
   File file = SPIFFS.open("/control.js", "r");
   size_t sent = server.streamFile(file, "application/javascript");
   file.close();
  void css(){
   File file = SPIFFS.open("/inner.css", "r");
   size_t sent = server.streamFile(file, "text/css");
   file.close();
void okoon(){
   File file = SPIFFS.open("/okoon.png", "r");
   size_t sent = server.streamFile(file, "image/png");
   file.close();
  void okooff(){
   File file = SPIFFS.open("/okooff.png", "r");
   file.close();
  void boom(){
   File file = SPIFFS.open("/okoboom.png", "r");
   file.close();
  void mboom(){
   File file = SPIFFS.open("/okomboom.png", "r");
   file.close();
void buildXML() {
  XML = "<?xml version='1.0'?>";
  XML += "<datafeeder>";
  XML += "<tempIN>klient 1: "+zprava1+"</tempIN>";
  XML += "<tempOUT>klient 2: "+zprava2+"</tempOUT>";
  XML += "<runtime>" +String(millis()/1000)+" sec</runtime>";
  XML += "</datafeeder>";
void handleXML()
  buildXML();
  server.send(200, "text/xml", XML);
void setup(void)
  pinMode(BUILTIN_LED, OUTPUT);
  digitalWrite(BUILTIN_LED, 0);
  WiFi.begin(ssid, password);
  Serial.println("");
  SPIFFS.begin();
  Dir dir = SPIFFS.openDir("/");
  while (dir.next())
    String fileName = dir.fileName();
    size_t fileSize = dir.fileSize();
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.print("Pripojeno k ");
  Serial.println(ssid);
  Serial.print("IP adresa: ");
  server.on("/xml", handleXML);
  server.on("/", printhtml);
  server.on("/index.htm", printhtml);
  server.on("/control.js" , js);
  server.on("/inner.css" , css);
  server.onNotFound(nenalezeno);
  server.on("/okoon.png" , okoon);
  server.on("/okooff.png" , okooff);
  server.on("/okoboom.png" , boom);
  server.on("/okomboom.png" , mboom);
  server.begin();
  Serial.println("HTTP server startuje");
void loop(void)
  server.handleClient();
  buildXML();
  digitalWrite(BUILDIN_LED, LOW);
void zapis(IPAddress ipa){
if(ipa==ip1){zprava1 +=server.arg("stat");}
else if(ipa==ip2){zprava2 +=server.arg("stat");}
else{
  if(ip1==""){ipa=ip1;
  else if(ip2==""){ipa=ip2;
v podstatě je to server ovládající webovou stránku s css,js,.. Ale jde mi o to že jako začátečník bych chtěl zkusit udělat takový malý (a primitivní) webový chat. Zobrazení na webu si vyřeším ale mám problém s příkazy client.,,,
Vyhodí mi to krom jiného co odladím tuto chybu. ↓↓ Myslím že mi tam chybí nějaká knihovna, nebo jiná podobná chyba. Knihovny jsem zkoušel přeinstalovat
exit status 1
'class ESP8266WebServer' has no member named 'available'
Předem děkuji za veškeré rady, v případě potřeby pošlu soubory ze souborového systému.
wes server
Re: problém s webservrem
Příspěvek od wes server » 09 kvě 2018, 17:31
vyřešeno, chyběl řádek kódu
