Graficke rozhrani ArduBlosk
purs
Příspěvek od purs » 21 led 2018, 17:04
Do IDE 1.8.3 jse si pridal ArduBlock. Jde to spustit, ulozit. nacist, ale bohuzel to negeneruje kod. :(
V IDE to pise tyto hlasky:
Exception in thread "AWT-EventQueue-0" java.lang.NoSuchMethodError: processing.app.Editor.setText(Ljava/lang/String;)V
at com.ardublock.ArduBlockTool.didGenerate(ArduBlockTool.java:62)
at com.ardublock.core.Context.didGenerate(Context.java:253)
at com.ardublock.ui.listener.GenerateCodeButtonListener.actionPerformed(GenerateCodeButtonListener.java:174)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.Component.processMouseEvent(Component.java:6533)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6298)
at java.awt.Container.processEvent(Container.java:2236)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2294)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
at java.awt.Container.dispatchEventImpl(Container.java:2280)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:90)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue$4.run(EventQueue.java:729)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
purs
Re: Graficke rozhrani ArduBlosk
Příspěvek od purs » 23 led 2018, 14:38
Omlouvan se za chybu v nadpisu, melo byt ArduBlock.
Podarilo se me to rozchodit pod IDE 1.6.9 . Moje puvodni 1.8.3 s tim nefungovalo.
Jinak je to zajimave, ale pro male deti. Budu na tom testovat vnuka 7 let.
Příspěvek od martinius96 » 23 led 2018, 15:02
Rovnaký "systém" programovania sa dá zapnúť i na online simulátore.
https://www.tinkercad.com/
