TFT LCD Modul a Arduino UNO
Napsal: 25 pro 2017, 23:34
mám problém s tímto:https://store.arduino.cc/arduino-lcd-screen displayem.
Nainstaloval jsem všechny knihovny které jsou na arduino.cc napsány jako potřebné, otevřel jsem v Arduino IDE ten nejzákladnější příklad pro "zobrazení" loga Arduina, jenže ani kompilace neproběhla úspěšně..
Používám tento kód:
Vypsal se tento error:
Mohl by mi někdo prosím vás poradit? já fakt nevím co s tim...Předem děkuji všem za odpovědi
OFryauf
Používám tento kód:
Arduino TFT Bitmap Logo example
This example reads an image file from a micro-SD card
and draws it on the screen, at random locations.
In this sketch, the Arduino logo is read from a micro-SD card.
There is a .bmp file included with this sketch.
- open the sketch folder (Ctrl-K or Cmd-K)
- copy the "arduino.bmp" file to a micro-SD
- put the SD into the SD slot of the Arduino TFT module.
This example code is in the public domain.
Created 19 April 2013 by Enrico Gueli
http://arduino.cc/en/Tutorial/TFTBitmapLogo
// include the necessary libraries
#include <SPI.h>
#include <SD.h>
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library
#include <TFT.h> // Arduino LCD library
// pin definition for the Uno
#define sd_cs 4
#define lcd_cs 10
#define dc 9
#define rst 8
// pin definition for the Leonardo
//#define sd_cs 8
//#define lcd_cs 7
//#define dc 0
//#define rst 1
TFT TFTscreen = TFT(lcd_cs, dc, rst);
// this variable represents the image to be drawn on screen
PImage logo;
// initialize the GLCD and show a message
// asking the user to open the serial line
TFTscreen.begin();
TFTscreen.background(255, 255, 255);
TFTscreen.stroke(0, 0, 255);
TFTscreen.println();
TFTscreen.println("Arduino TFT Bitmap Example");
TFTscreen.stroke(0, 0, 0);
TFTscreen.println("Open serial monitor");
TFTscreen.println("to run the sketch");
// initialize the serial port: it will be used to
// print some diagnostic info
while (!Serial) {
// wait for serial line to be ready
// clear the GLCD screen before starting
// try to access the SD card. If that fails (e.g.
// no card present), the setup process will stop.
Serial.print("Initializing SD card...");
if (!SD.begin(sd_cs)) {
Serial.println("failed!");
return;
Serial.println("OK!");
// initialize and clear the GLCD screen
TFTscreen.begin();
// now that the SD card can be access, try to load the
// image file.
logo = TFTscreen.loadImage("arduino.bmp");
if (!logo.isValid()) {
Serial.println("error while loading arduino.bmp");
// don't do anything if the image wasn't loaded correctly.
if (logo.isValid() == false) {
return;
Serial.println("drawing image");
// get a random location where to draw the image.
// To avoid the image to be draw outside the screen,
// take into account the image size.
int x = random(TFTscreen.width() - logo.width());
int y = random(TFTscreen.height() - logo.height());
// draw the image to the screen
TFTscreen.image(logo, x, y);
// wait a little bit before drawing again
delay(1500);
Arduino: 1.8.5 (Windows 10), Vývojová deska: "Arduino/Genuino Uno"
TFTBitmapLogo:44: error: 'PImage' does not name a type
PImage logo;
C:\Users\ondra\Documents\Arduino\libraries\TFT-master\examples\Arduino\TFTBitmapLogo\TFTBitmapLogo.ino: In function 'void setup()':
TFTBitmapLogo:51: error: 'class TFT' has no member named 'background'
TFTBitmapLogo:53: error: 'class TFT' has no member named 'stroke'
TFTBitmapLogo:56: error: 'class TFT' has no member named 'stroke'
TFTBitmapLogo:68: error: 'class TFT' has no member named 'background'
TFTBitmapLogo:81: error: 'class TFT' has no member named 'background'
TFTBitmapLogo:85: error: 'logo' was not declared in this scope
TFTBitmapLogo:85: error: 'class TFT' has no member named 'loadImage'
C:\Users\ondra\Documents\Arduino\libraries\TFT-master\examples\Arduino\TFTBitmapLogo\TFTBitmapLogo.ino: In function 'void loop()':
TFTBitmapLogo:93: error: 'logo' was not declared in this scope
TFTBitmapLogo:102: error: 'logo' was not declared in this scope
TFTBitmapLogo:106: error: 'class TFT' has no member named 'image'
Byly nalezené násobné knihovny "TFT.h"
Použitý: C:\Program Files (x86)\Arduino\libraries\TFT
Nepoužitý: C:\Users\ondra\Documents\Arduino\libraries\TFT-master
Byly nalezené násobné knihovny "SD.h"
Použitý: C:\Users\ondra\Documents\Arduino\libraries\SD
Nepoužitý: C:\Program Files (x86)\Arduino\libraries\SD
exit status 1
OFryauf
