konverze kodu
Ludek
konverze kodu
Příspěvek od Ludek » 26 čer 2024, 12:46
Zdravím,
dokázal by někdo konvertovat tento program pro UNO - resp ATMega 328P
Je to testovací program pro tft display a nedaří se mi to.
/********************金逸晨**************************
*****************模块 1.9寸   8PIN SPI TFT FOR C51*************
*****C51*************驱动**************************
*********ST7789
默认数据格式位RGB565
本模块自带背光限流电阻,使用BL 引脚调整背光亮度,推荐使用pwm信号控制亮度,也可直接高电平
#include "reg51.h"
#define set_0   0x01
#define set_1   0x02
#define set_2   0x04
#define set_3   0x08
#define set_4   0x10
#define set_5   0x20
#define set_6   0x40
#define set_7   0x80
#define clr_0   0xFE
#define clr_1   0xFD
#define clr_2   0xFB
#define clr_3   0xF7
#define clr_4   0xEF
#define clr_5   0xDF
#define clr_6   0xBF
#define clr_7   0x7F
/**********SPI引脚分配,连接oled屏,更具实际情况修改*********/
#define SPI_SCK_0  P3 &=clr_0        //P3_0
#define SPI_SCK_1  P3|=set_0
#define SPI_SDA_0  P3&=clr_1        //P3_1
#define SPI_SDA_1  P3|=set_1
#define SPI_RST_0  P3&=clr_2        //P3_2
#define SPI_RST_1  P3|=set_2
#define SPI_DC_0  P3&=clr_3           //P3_3
#define SPI_DC_1  P3|=set_3
#define SPI_CS_0  P3&=clr_4          //P3_4
#define SPI_CS_1  P3|=set_4
#define     RED          0XF800	  //红色
#define     GREEN        0X07E0	  //绿色
#define     BLUE         0X001F	  //蓝色
#define     WHITE        0XFFFF	  //白色
#define TFT_COLUMN_NUMBER 170
#define TFT_LINE_NUMBER 320
#define TFT_COLUMN_OFFSET 35
#define PIC_NUM 28800			//图片数据大小
const unsigned char  *point;
code unsigned char  chines_word[   ][32]=   //汉字码
0x00,0x00,0xE4,0x3F,0x28,0x20,0x28,0x25,0x81,0x08,0x42,0x10,0x02,0x02,0x08,0x02,
0xE8,0x3F,0x04,0x02,0x07,0x07,0x84,0x0A,0x44,0x12,0x34,0x62,0x04,0x02,0x00,0x02,/*"深",0*/
0x88,0x20,0x88,0x24,0x88,0x24,0x88,0x24,0x88,0x24,0xBF,0x24,0x88,0x24,0x88,0x24,
0x88,0x24,0x88,0x24,0x88,0x24,0xB8,0x24,0x87,0x24,0x42,0x24,0x40,0x20,0x20,0x20,/*"圳",1*/
0x80,0x00,0x80,0x00,0x40,0x01,0x20,0x02,0x10,0x04,0x08,0x08,0xF4,0x17,0x83,0x60,
0x80,0x00,0xFC,0x1F,0x80,0x00,0x88,0x08,0x90,0x08,0x90,0x04,0xFF,0x7F,0x00,0x00,/*"金",2*/
0x80,0x00,0x82,0x00,0x84,0x0F,0x44,0x08,0x20,0x04,0xF0,0x3F,0x27,0x22,0x24,0x22,
0xE4,0x3F,0x04,0x05,0x84,0x0C,0x84,0x54,0x44,0x44,0x24,0x78,0x0A,0x00,0xF1,0x7F,/*"逸",3*/
0xF8,0x0F,0x08,0x08,0xF8,0x0F,0x08,0x08,0xF8,0x0F,0x00,0x00,0xFC,0x3F,0x04,0x00,
0xF4,0x1F,0x04,0x00,0xFC,0x7F,0x94,0x10,0x14,0x09,0x12,0x06,0x52,0x18,0x31,0x60,/*"晨",4*/
0x80,0x00,0x80,0x00,0x80,0x00,0xFC,0x1F,0x84,0x10,0x84,0x10,0x84,0x10,0xFC,0x1F,
0x84,0x10,0x84,0x10,0x84,0x10,0xFC,0x1F,0x84,0x50,0x80,0x40,0x80,0x40,0x00,0x7F,/*"电",5*/
0x00,0x00,0xFE,0x1F,0x00,0x08,0x00,0x04,0x00,0x02,0x80,0x01,0x80,0x00,0xFF,0x7F,
0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0xA0,0x00,0x40,0x00,/*"子",6*/
void delay_us(unsigned int _us_time)
  unsigned char x=0;
  for(;_us_time>0;_us_time--)
    x++;
void Delay_ms(unsigned int _ms_time)
    unsigned int i,j;
    for(i=0;i<_ms_time;i++)
    for(j=0;j<900;j++)
/*************SPI配置函数*******************
SCL空闲时低电平,第一个上升沿采样
模拟SPI
/**************************SPI模块发送函数************************************************
void SPI_SendByte(unsigned  char byte)				//向液晶屏写一个8位数据
  unsigned char counter;
  for(counter=0;counter<8;counter++)
    SPI_SCK_0;
    if((byte&0x80)==0)
      SPI_SDA_0;
    else SPI_SDA_1;
    byte=byte<<1;
    SPI_SCK_1;
	SPI_SCK_0;
void TFT_SEND_CMD(unsigned char o_command)
	SPI_DC_0;
	SPI_CS_0;
    SPI_SendByte(o_command);
	  SPI_CS_1;
  //向液晶屏写一个8位数据
void TFT_SEND_DATA(unsigned  char o_data)
    SPI_DC_1;
	SPI_CS_0;
    SPI_SendByte(o_data);
	SPI_CS_1;
void TFT_clear(void)
    unsigned int ROW,column;
  TFT_SEND_CMD(0x2a);     //Column address set
  TFT_SEND_DATA(0x00);    //start column
  TFT_SEND_DATA(0x00+TFT_COLUMN_OFFSET);
  TFT_SEND_DATA(0x00);    //end column
  TFT_SEND_DATA(0xA9+TFT_COLUMN_OFFSET);
  TFT_SEND_CMD(0x2b);     //Row address set
  TFT_SEND_DATA(0x00);    //start row
  TFT_SEND_DATA(0x01);    //end row
  TFT_SEND_DATA(0x3F);
    TFT_SEND_CMD(0x2C);     //Memory write
    for(ROW=0;ROW<TFT_LINE_NUMBER;ROW++)             //ROW loop
          for(column=0;column<TFT_COLUMN_NUMBER;column++)  //column loop
				TFT_SEND_DATA(0xFF);
void TFT_full(unsigned int color)
  for(column=0;column<TFT_COLUMN_NUMBER ;column++) //column loop
			TFT_SEND_DATA(color>>8);
			  TFT_SEND_DATA(color);
void TFT_init(void)				////ST7789V2
	SPI_SCK_1;			//特别注意!!
	SPI_RST_0;
	Delay_ms(1000);
	SPI_RST_1;
	Delay_ms(1000);
    TFT_SEND_CMD(0x11); 			//Sleep Out
	Delay_ms(120);               //DELAY120ms
	 	  //-----------------------ST7789V Frame rate setting-----------------//
                TFT_SEND_CMD(0x3A);        //65k mode
                TFT_SEND_DATA(0x05);
                TFT_SEND_CMD(0xC5); 		//VCOM
                TFT_SEND_DATA(0x1A);
                TFT_SEND_CMD(0x36);                 // 屏幕显示方向设置
                //-------------ST7789V Frame rate setting-----------//
                TFT_SEND_CMD(0xb2);		//Porch Setting
                TFT_SEND_DATA(0x33);
                TFT_SEND_CMD(0xb7);			//Gate Control
                TFT_SEND_DATA(0x05);			//12.2v   -10.43v
                //--------------ST7789V Power setting---------------//
                TFT_SEND_CMD(0xBB);//VCOM
                TFT_SEND_CMD(0xC0); //Power control
                TFT_SEND_DATA(0x2c);
                TFT_SEND_CMD(0xC2);		//VDV and VRH Command Enable
                TFT_SEND_CMD(0xC3);			//VRH Set
                TFT_SEND_DATA(0x0F);		//4.3+( vcom+vcom offset+vdv)
                TFT_SEND_CMD(0xC4);			//VDV Set
                TFT_SEND_DATA(0x20);				//0v
                TFT_SEND_CMD(0xC6);				//Frame Rate Control in Normal Mode
                TFT_SEND_DATA(0X01);			//111Hz
                TFT_SEND_CMD(0xd0);				//Power Control 1
                TFT_SEND_DATA(0xa4);
                TFT_SEND_DATA(0xa1);
                TFT_SEND_CMD(0xE8);				//Power Control 1
                TFT_SEND_DATA(0x03);
                TFT_SEND_CMD(0xE9);				//Equalize time control
                TFT_SEND_DATA(0x09);
                TFT_SEND_DATA(0x08);
                //---------------ST7789V gamma setting-------------//
                TFT_SEND_CMD(0xE0); //Set Gamma
                TFT_SEND_DATA(0xD0);
                TFT_SEND_DATA(0x14);
                TFT_SEND_DATA(0x28);
                TFT_SEND_DATA(0x07);
                TFT_SEND_DATA(0x13);
                TFT_SEND_DATA(0x30);
                TFT_SEND_CMD(0XE1); //Set Gamma
                TFT_SEND_DATA(0x24);
                TFT_SEND_DATA(0x32);
                TFT_SEND_DATA(0x3B);
                TFT_SEND_DATA(0x2F);
                TFT_SEND_CMD(0x21); 		//反显
                TFT_SEND_CMD(0x29);         //开启显示
void display_char16_16(unsigned int x,unsigned int y,unsigned long color,unsigned char word_serial_number)
   unsigned int column;
  unsigned char tm=0,temp=0,xxx=0;
  TFT_SEND_DATA(x>>8);    //start column
  TFT_SEND_DATA(x);
  x=x+15;
  TFT_SEND_DATA(x>>8);    //end column
  TFT_SEND_DATA(x);
  TFT_SEND_DATA(y>>8);    //start row
  TFT_SEND_DATA(y);
  y=y+15;
  TFT_SEND_DATA(y>>8);    //end row
  TFT_SEND_DATA(y);
  for(column=0;column<32;column++)  //column loop
        temp=chines_word[  word_serial_number ][xxx];
        for(tm=0;tm<8;tm++)
        if(temp&0x01)
        else
          TFT_SEND_DATA(0XFF);
          temp>>=1;
        xxx++;
void IO_init(void)
  P3|=0xFF;
int main()
	IO_init();
	SPI_SCK_0;
	TFT_init();
	while(1)
	TFT_full(RED);
	Delay_ms(10);
	TFT_full(GREEN);
	Delay_ms(20);
	TFT_full(BLUE);
	Delay_ms(20);
	TFT_clear();
    display_char16_16(20,160,BLUE,0);
	display_char16_16(36,160,GREEN,1);
	display_char16_16(60,160,RED,2);
	display_char16_16(76,160,BLUE,3);
	display_char16_16(92,160,GREEN,4);
	display_char16_16(118,160,BLUE,5);
	display_char16_16(134,160,RED,6);
	Delay_ms(10);
Re: konverze kodu
Příspěvek od jankop » 26 čer 2024, 14:56
To je vcelku na nic. Nahraj si do IDE knihovnu adafruit ST7789, je v nabídce. Nejspíš u ní bude i testovací program.
Ludek
Re: konverze kodu
Příspěvek od Ludek » 26 čer 2024, 17:53
Jo to vím...
jenomže já reklamuji display na Aliexpressu a číňan asi nevěří kódu z knihovny
a poslal toto abych to zkusil a poslal výsledek. A to neumím :-(
Re: konverze kodu
Příspěvek od kiRRow » 26 čer 2024, 18:35
tak mu pošli tohle jako výsledek
Ludek
Re: konverze kodu
Příspěvek od Ludek » 26 čer 2024, 18:55
to jsem poslal a oni tomu nevěří a poslali ten jejich kod.
