Blikací majáky.
jugger
Blikací majáky.
Příspěvek od jugger » 03 pro 2022, 23:43
Dobrý den
Může mi prosím někdo poradit jak pomocí jednoho tlačítka preskočit na další nastavené blikání ?? Hledal jsem ale nějak mi nic nejde :cry:
void mix_rwb , void mix_rb atd... ?
Díky
#include <FastLED.h>
#define LED_PIN     5
#define NUM_LEDS    16
// #define BUTTON_PIN 2
// int buttonPin = 2;
int strobo_1 = 30;
int strobo_2 = 50;
int strobo_3 = 80;
int strobo_4 = 100;
int freq_1 = 10;
int freq_2 = 30;
int freq_3 = 100;
int Pot = A0;
int PotVal = 0;
int OutVal = 0;
CRGB leds[NUM_LEDS];
  FastLED.addLeds<WS2812, LED_PIN, GRB>(leds, NUM_LEDS);
  // FastLED.setBrightness(MAX_BRIGHTNESS);
void mix_rwb()  {
  for (int i = 0; i <= 6; i++) {
    leds[0] = CRGB (255, 0, 0);
    leds[1] = CRGB (255, 0, 0);
    leds[2] = CRGB (255, 0, 0);
    leds[3] = CRGB (255, 0, 0);
    leds[4] = CRGB (255, 255, 255);
    leds[5] = CRGB (255, 255, 255);
    leds[6] = CRGB (255, 255, 255);
    leds[7] = CRGB (255, 255, 255);
    leds[8] = CRGB (255, 255, 255);
    leds[9] = CRGB (255, 255, 255);
    leds[10] = CRGB (255, 255, 255);
    leds[11] = CRGB (255, 255, 255);
    leds[12] = CRGB (0, 0, 255);
    leds[13] = CRGB (0, 0, 255);
    leds[14] = CRGB (0, 0, 255);
    leds[15] = CRGB (0, 0, 255);
    FastLED.show();
    delay(strobo_1);
    FastLED.clear ();
    delay(strobo_1);
    FastLED.show();
    delay(strobo_1);
void mix_rb()  {
  for (int i = 0; i <= 3; i++) {
    leds[4] = CRGB (255, 0, 0);
    leds[5] = CRGB (255, 0, 0);
    leds[6] = CRGB (255, 0, 0);
    leds[7] = CRGB (255, 0, 0);
    leds[8] = CRGB (0, 0, 255);
    leds[9] = CRGB (0, 0, 255);
    leds[10] = CRGB (0, 0, 255);
    leds[11] = CRGB (0, 0, 255);
    FastLED.show();
    delay(strobo_1);
    FastLED.clear ();
    delay(strobo_1);
    leds[15] = CRGB (255, 0, 0);
    leds[14] = CRGB (255, 0, 0);
    leds[13] = CRGB (2550, 0, 0);
    leds[12] = CRGB (2550, 0, 0);
    leds[11] = CRGB (2550, 0, 0);
    leds[10] = CRGB (2550, 0, 0);
    leds[9] = CRGB (2550, 0, 0);
    leds[8] = CRGB (2550, 0, 0);
    leds[7] = CRGB (0, 0, 255);
    leds[6] = CRGB (0, 0, 255);
    leds[5] = CRGB (0, 0, 255);
    leds[4] = CRGB (0, 0, 255);
    leds[3] = CRGB (0, 0, 255);
    leds[2] = CRGB (0, 0, 255);
    leds[1] = CRGB (0, 0, 255);
    leds[0] = CRGB (0, 0, 255);
    FastLED.show();
    delay(strobo_1);
    FastLED.clear ();
    delay(strobo_1);
    PotVal = analogRead(Pot);
    Serial.println(OutVal);
    OutVal = map(PotVal, 0, 1023, 0, 255);
    analogWrite(NUM_LEDS, OutVal);
    FastLED.setBrightness(OutVal);
  mix_rb();
  delay(strobo_4);
   mix_rwb();
   delay(strobo_2);
Edit: Používej tag code (tlačítko </>)
Naposledy upravil(a) gilhad dne 14 pro 2022, 13:16, celkem upraveno 1 x.
Důvod: Edit: Používej tag code (tlačítko </>)
Re: Blikací majáky.
Příspěvek od AstroMiK » 04 pro 2022, 17:50
Zarytí odpůrci funkce delay() by ti řekli, že je ten program špatně napsaný a je nutné ho od základu předělat.
Kdybych ale měl použít to co je, tak bych na začátek programu (před blok setup) zavedl jednu globální proměnnou:
byte styl;
V bloku setup() bych nastavil ten vstup pro tlačítko:
  pinMode(BUTTON_PIN, INPUT_PULLUP);
A do hlavní smyčky bych pak místo posledních 4 řádek přidal tenhle kód:
    if (digitalRead(BUTTON_PIN) == LOW)               // bylo stisknuto tlacitko
        styl ++;                                      // zmeni se styl blikani
        if (styl > 1) styl = 0;                       // pocet stylu blikani je v tomto pripade omezen jen na dva (0 a 1)
        delay(50);                                    // odruseni zakmitu pri stisku
        while (digitalRead(BUTTON_PIN) == LOW) ;      // ceka se dokud se tlacitko neuvolni
        delay(50);                                    // odruseni zakmitu pri uvolneni
    switch (styl)                                     // prepnuti na nastaveny styl blikani
        case 0:
          mix_rb();
          delay(strobo_4);
        case 1:
          mix_rwb();
          delay(strobo_2);
Má to teda trochu nevýhodu v tom, že se bude muset držet to tlačítko tak dlouho, než se dokončí předchozí sekvence blikání.
Když to ale počítám, tak by to nikdy nemělo být déle než 0,3 sekundy a to se dá ještě vydržet.
Při delších sekvencích (přes sekundu) už by to ale bylo docela blbý.
Mimochodem, co tam má znamenat ta řádka:
Na pinu 16 (existuje vůbec na tvém Arduinu?) se mění střída PWM signálu podle natočení potenciometru.
jugger
Re: Blikací majáky.
Příspěvek od jugger » 04 pro 2022, 20:56
Jo něco o delay jsem četl že to není zrovna vhodný ale je to promazanej větší program . Předělat to celý je nad moje schopnosti.
HW pro mě problém není ale SW jo :) . Po vložení to funguje tak mooc děkuju :D
Maximálně se mi ještě podaří implementovat pípání a dětičky budou spokojený.
analogWrite(NUM_LEDS, OutVal); je pozustatek k ničemu smazal jsem .
Ještě jednou děkuju .
jugger
Re: Blikací majáky.
Příspěvek od jugger » 13 pro 2022, 23:23
Tak HW už je . Přidal jsem potenciometr na jas a druhý na rychlost.
Pak také piezo na bee bee , ale nedaří se mi udělat melodii k blikání ... asi funkce delay ? A pak taky tu melodii když je to podle not :-/ Nějaký lepší nápad?
Ještě krabičku a je to .
Někdo kdo by to předělal do funkčního stavu aby to beepalo a zároveň blikalo ? Za rozumnou odměnu samozřejmě.
Pak ještě otázka dá se místo každé led napsat 1,2,3 barva xxx a podobně ? taky mi to nejde :(
Děkuji.
Re: Blikací majáky.
Příspěvek od kiRRow » 14 pro 2022, 14:44
Buď delay (jakmile se program dostane k delay, tak v praxi se zacykluje v prázdné smyčce a není schopen bez přerušení vykonávat jiný kód - toť důvod proč hodně lidí delay doslova nenávidí), nebo používáš takovou kombinaci knihoven, že se perou o časovač.
jugger
Re: Blikací majáky.
Příspěvek od jugger » 15 pro 2022, 21:06
Sotva jsem to vykopíroval a sestavil takže na víc asi nestačím :cry:
Radši hardware , něco svařit, sestavit, vyrobit, sehnat ale software nee :D
Re: Blikací majáky.
Příspěvek od Axamith » 16 pro 2022, 18:25
Nevzdávej to, většina z nás začínala od nuly, kopírováním cizích kódů. Nějak se začít musí.
Re: Blikací majáky.
Příspěvek od kiRRow » 16 pro 2022, 19:12
Opět znovu, prosím, celý kód... včetně knihoven... jestli je i nějaký výpis ze sériové linky ....... Ať nemusíme žhavit věštecký koule ...
jugger
Re: Blikací majáky.
Příspěvek od jugger » 16 pro 2022, 20:40
Mám to takto .. pitches.h jsou ty noty to jsem už nepoužil, tak to jen bliká .
Bohužel mám dost jiný práce než se učit arduino i když bych rád.
U PLC jsem skončil u siemens loga to jde celkem v pohodě a zatím stačilo na vše.
Normální majáky mám ale to je dost nekompaktní balení na hraní pro děti :lol:
#define LED_PIN     5
#define NUM_LEDS    32
int buttonPin = 2;
// #include "pitches.h"
int strobo_1 = 40;
int strobo_2 = 50;
int strobo_3 = 80;
int strobo_4 = 100;
int freq_1 = 10;
int freq_2 = 30;
int freq_3 = 100;
int freq_pattern_1 = 40;
int Pot = A0;
int PotVal = 0;
int OutVal = 0;
int PotSpeed = A1;
int PotValSpeed = 0;
int OutValSpeed = 0;
byte styl;
void mix_rwb()  {
    leds[16] = CRGB (255, 0, 0);
    leds[17] = CRGB (255, 0, 0);
    leds[18] = CRGB (255, 0, 0);
    leds[19] = CRGB (255, 0, 0);
    leds[20] = CRGB (255, 255, 255);
    leds[21] = CRGB (255, 255, 255);
    leds[22] = CRGB (255, 255, 255);
    leds[23] = CRGB (255, 255, 255);
    leds[24] = CRGB (255, 255, 255);
    leds[25] = CRGB (255, 255, 255);
    leds[26] = CRGB (255, 255, 255);
    leds[27] = CRGB (255, 255, 255);
    leds[28] = CRGB (0, 0, 255);
    leds[29] = CRGB (0, 0, 255);
    leds[30] = CRGB (0, 0, 255);
    leds[31] = CRGB (0, 0, 255);
    FastLED.show();
    delay(strobo_1);
    FastLED.clear ();
    delay(strobo_1);
    FastLED.show();
    delay(strobo_1);
void mix_rb()  {
    leds[20] = CRGB (255, 0, 0);
    leds[21] = CRGB (255, 0, 0);
    leds[22] = CRGB (255, 0, 0);
    leds[23] = CRGB (255, 0, 0);
    leds[24] = CRGB (0, 0, 255);
    leds[25] = CRGB (0, 0, 255);
    leds[26] = CRGB (0, 0, 255);
    leds[27] = CRGB (0, 0, 255);
    FastLED.show();
    delay(OutValSpeed);
    FastLED.clear ();
     delay(OutValSpeed);
    FastLED.clear ();
    leds[8] = CRGB (255, 0, 0);
    leds[9] = CRGB (255, 0, 0);
    leds[10] = CRGB (255, 0, 0);
    leds[11] = CRGB (255, 0, 0);
    leds[12] = CRGB (255, 0, 0);
    leds[13] = CRGB (255, 0, 0);
    leds[16] = CRGB (0, 0, 255);
    leds[17] = CRGB (0, 0, 255);
    leds[18] = CRGB (0, 0, 255);
    leds[19] = CRGB (0, 0, 255);
    leds[20] = CRGB (0, 0, 255);
    leds[21] = CRGB (0, 0, 255);
    leds[22] = CRGB (0, 0, 255);
    leds[23] = CRGB (0, 0, 255);
    leds[24] = CRGB (255, 0, 0);
    leds[25] = CRGB (255, 0, 0);
    leds[26] = CRGB (255, 0, 0);
    leds[27] = CRGB (255, 0, 0);
    leds[28] = CRGB (255, 0, 0);
    leds[29] = CRGB (255, 0, 0);
    leds[30] = CRGB (255, 0, 0);
    leds[31] = CRGB (255, 0, 0);
    FastLED.show();
    delay(OutValSpeed);
    FastLED.clear ();
    delay(OutValSpeed);
void looping() {
       for(int j = 0; j < 256; j++) {
   for(int i = 0; i < NUM_LEDS; i++) {
      leds[i] = Scroll((i * 256 / NUM_LEDS + j) % 256);
    FastLED.show();
    delay(1);
// WS2812B LED Strip switches Red and Green
CRGB Scroll(int pos) {
  CRGB color (0,0,0);
  if(pos < 85) {
    color.g = 0;
    color.r = ((float)pos / 85.0f) * 255.0f;
    color.b = 255 - color.r;
  } else if(pos < 170) {
    color.g = ((float)(pos - 85) / 85.0f) * 255.0f;
    color.r = 255 - color.g;
    color.b = 0;
  } else if(pos < 256) {
    color.b = ((float)(pos - 170) / 85.0f) * 255.0f;
    color.g = 255 - color.b;
    color.r = 1;
  return color;
    OutVal = map(PotVal, 0, 1023, 10, 255);
    PotValSpeed = analogRead(PotSpeed);
    Serial.println(OutValSpeed);
    OutValSpeed = map(PotValSpeed, 0, 1023, 150, 5);
        if (styl > 2) styl = 0;                       // pocet stylu blikani je v tomto pripade omezen jen na dva (0 a 1)
        case 0:
          mix_rb();
          delay(strobo_4);
        case 1:
          mix_rwb();
          delay(strobo_2);
        case 2:
          looping();
          delay(strobo_2);
Edit: Používej tag code ( tlačítko </> )
Naposledy upravil(a) gilhad dne 17 pro 2022, 10:24, celkem upraveno 1 x.
Důvod: Edit: Používej tag code ( tlačítko </> )
Re: Blikací majáky.
Příspěvek od kiRRow » 17 pro 2022, 14:19
Jo to ti dělají ty delay v mix_rwb a mix_rb. Jestli chceš k tomu i zvuk, nemůžeš procesor zastavovat, je třeba pomocí millis micros dělat multitasking.
    FastLED.show();
    delay(strobo_1);
    FastLED.clear ();
    delay(strobo_1);
    FastLED.show();
    delay(strobo_1);
// jaký je smysl pořád neustále nastavovat leds ... smysl to má jen když místo konstantního čísla používáš proměnnou tak jako ve funkci looping ...
    FastLED.show();
    delay(strobo_1);
    FastLED.clear ();
    delay(strobo_1);
    FastLED.show();
    delay(strobo_1);
