Príklad pre 2,4" dotykový displej chyba kompilácie
Matko
Příspěvek od Matko » 03 črc 2022, 18:07
Ahojte nedarí sa mi rozbehať malý dotykový displej 2.4" 240*320 ILI9341 pripojený na STM32.
Otvoril som príklad pre Adafruit_ILI9341 graphicstest a pri kompilácii vypisuje chybu:
C:\Users\Martin\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp: In member function 'bool Adafruit_I2CDevice::write(const uint8_t*, size_t, bool, const uint8_t*, size_t)':
C:\Users\Martin\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp:110:47: error: invalid conversion from 'const uint8_t* {aka const unsigned char*}' to 'uint8* {aka unsigned char*}' [-fpermissive]
if (_wire->write(prefix_buffer, prefix_len) != prefix_len) {
In file included from C:\Users\Martin\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\Wire/Wire.h:42:0,
from C:\Users\Martin\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.h:5,
from C:\Users\Martin\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp:1:
C:\Users\Martin\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\Wire/utility/WireBase.h:123:12: error: initializing argument 1 of 'size_t WireBase::write(uint8*, int)' [-fpermissive]
size_t write(uint8*, int);
C:\Users\Martin\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp:119:31: error: invalid conversion from 'const uint8_t* {aka const unsigned char*}' to 'uint8* {aka unsigned char*}' [-fpermissive]
if (_wire->write(buffer, len) != len) {
Boli nájdené násobné knižnice pre "Wire.h"
Použité: C:\Users\Martin\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\Wire
Nepoužité: C:\Users\Martin\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\WireSlave
exit status 1
Nastala chyba pri kompilácii pre dosku Generic STM32F103C6/fake STM32F103C8.
výpis programu:
  This is our GFX example for the Adafruit ILI9488 Breakout and Shield
  ----> http://www.adafruit.com/products/1651
  Check out the links above for our tutorials and wiring diagrams
  These displays use SPI to communicate, 4 or 5 pins are required to
  interface (RST is optional)
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  MIT license, all text above must be included in any redistribution
#include "SPI.h"
#include <Adafruit_GFX.h>
#include <ILI9488.h>
#define TFT_CS         PA1
#define TFT_DC         PB3
#define TFT_LED        PB0
#define TFT_RST        PB4
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
ILI9488 tft = ILI9488(TFT_CS, TFT_DC, TFT_RST);
// If using the breakout, change pins as desired
//Adafruit_ILI9488 tft = Adafruit_ILI9488(TFT_CS, TFT_DC, TFT_MOSI, TFT_CLK, TFT_RST, TFT_MISO);
  Serial.println("ILI9488 Test!");
  tft.begin();
  // read diagnostics (optional but can help debug problems)
  uint8_t x = tft.readcommand8(ILI9488_RDMODE);
  Serial.print("Display Power Mode: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9488_RDMADCTL);
  Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9488_RDPIXFMT);
  Serial.print("Pixel Format: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9488_RDIMGFMT);
  Serial.print("Image Format: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9488_RDSELFDIAG);
  Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX);
  Serial.println(F("Benchmark                Time (microseconds)"));
  Serial.print(F("Screen fill              "));
  Serial.println(testFillScreen());
  delay(500);
  Serial.print(F("Text                     "));
  Serial.println(testText());
  delay(3000);
  Serial.print(F("Lines                    "));
  Serial.println(testLines(ILI9488_CYAN));
  delay(500);
  Serial.print(F("Horiz/Vert Lines         "));
  Serial.println(testFastLines(ILI9488_RED, ILI9488_BLUE));
  delay(500);
  Serial.print(F("Rectangles (outline)     "));
  Serial.println(testRects(ILI9488_GREEN));
  delay(500);
  Serial.print(F("Rectangles (filled)      "));
  Serial.println(testFilledRects(ILI9488_YELLOW, ILI9488_MAGENTA));
  delay(500);
  Serial.print(F("Circles (filled)         "));
  Serial.println(testFilledCircles(10, ILI9488_MAGENTA));
  Serial.print(F("Circles (outline)        "));
  Serial.println(testCircles(10, ILI9488_WHITE));
  delay(500);
  Serial.print(F("Triangles (outline)      "));
  Serial.println(testTriangles());
  delay(500);
  Serial.print(F("Triangles (filled)       "));
  Serial.println(testFilledTriangles());
  delay(500);
  Serial.print(F("Rounded rects (outline)  "));
  Serial.println(testRoundRects());
  delay(500);
  Serial.print(F("Rounded rects (filled)   "));
  Serial.println(testFilledRoundRects());
  delay(500);
  Serial.println(F("Done!"));
void loop(void) {
  for(uint8_t rotation=0; rotation<4; rotation++) {
    tft.setRotation(rotation);
    testText();
unsigned long testFillScreen() {
  unsigned long start = micros();
  tft.fillScreen(ILI9488_BLACK);
  tft.fillScreen(ILI9488_RED);
  tft.fillScreen(ILI9488_GREEN);
  tft.fillScreen(ILI9488_BLUE);
  return micros() - start;
unsigned long testText() {
  tft.setCursor(0, 0);
  tft.setTextColor(ILI9488_WHITE);  tft.setTextSize(1);
  tft.println("Hello World!");
  tft.setTextColor(ILI9488_YELLOW); tft.setTextSize(2);
  tft.println(1234.56);
  tft.setTextColor(ILI9488_RED);    tft.setTextSize(3);
  tft.println(0xDEADBEEF, HEX);
  tft.println();
  tft.setTextColor(ILI9488_GREEN);
  tft.setTextSize(5);
  tft.println("Groop");
  tft.setTextSize(2);
  tft.println("I implore thee,");
  tft.setTextSize(1);
  tft.println("my foonting turlingdromes.");
  tft.println("And hooptiously drangle me");
  tft.println("with crinkly bindlewurdles,");
  tft.println("Or I will rend thee");
  tft.println("in the gobberwarts");
  tft.println("with my blurglecruncheon,");
  tft.println("see if I don't!");
unsigned long testLines(uint16_t color) {
  unsigned long start, t;
  int           x1, y1, x2, y2,
                w = tft.width(),
                h = tft.height();
  x1 = y1 = 0;
  y2    = h - 1;
  start = micros();
  for(x2=0; x2<w; x2+=6) tft.drawLine(x1, y1, x2, y2, color);
  x2    = w - 1;
  for(y2=0; y2<h; y2+=6) tft.drawLine(x1, y1, x2, y2, color);
  t     = micros() - start; // fillScreen doesn't count against timing
  x1    = w - 1;
  y1    = 0;
  y2    = h - 1;
  start = micros();
  x2    = 0;
  t    += micros() - start;
  x1    = 0;
  y1    = h - 1;
  y2    = 0;
  start = micros();
  x2    = w - 1;
  x1    = w - 1;
  y1    = h - 1;
  y2    = 0;
  start = micros();
  x2    = 0;
unsigned long testFastLines(uint16_t color1, uint16_t color2) {
  unsigned long start;
  int           x, y, w = tft.width(), h = tft.height();
  start = micros();
  for(y=0; y<h; y+=5) tft.drawFastHLine(0, y, w, color1);
  for(x=0; x<w; x+=5) tft.drawFastVLine(x, 0, h, color2);
unsigned long testRects(uint16_t color) {
  int           n, i, i2,
                cx = tft.width()  / 2,
                cy = tft.height() / 2;
  n     = min(tft.width(), tft.height());
  start = micros();
  for(i=2; i<n; i+=6) {
    i2 = i / 2;
    tft.drawRect(cx-i2, cy-i2, i, i, color);
unsigned long testFilledRects(uint16_t color1, uint16_t color2) {
  unsigned long start, t = 0;
  int           n, i, i2,
                cx = tft.width()  / 2 - 1,
                cy = tft.height() / 2 - 1;
  for(i=n; i>0; i-=6) {
    i2    = i / 2;
    start = micros();
    tft.fillRect(cx-i2, cy-i2, i, i, color1);
    // Outlines are not included in timing results
    tft.drawRect(cx-i2, cy-i2, i, i, color2);
  return t;
unsigned long testFilledCircles(uint8_t radius, uint16_t color) {
  int x, y, w = tft.width(), h = tft.height(), r2 = radius * 2;
  start = micros();
  for(x=radius; x<w; x+=r2) {
    for(y=radius; y<h; y+=r2) {
      tft.fillCircle(x, y, radius, color);
unsigned long testCircles(uint8_t radius, uint16_t color) {
  int           x, y, r2 = radius * 2,
                w = tft.width()  + radius,
                h = tft.height() + radius;
  // Screen is not cleared for this one -- this is
  // intentional and does not affect the reported time.
  start = micros();
  for(x=0; x<w; x+=r2) {
    for(y=0; y<h; y+=r2) {
      tft.drawCircle(x, y, radius, color);
unsigned long testTriangles() {
  int           n, i, cx = tft.width()  / 2 - 1,
  n     = min(cx, cy);
  start = micros();
  for(i=0; i<n; i+=5) {
    tft.drawTriangle(
      cx    , cy - i, // peak
      cx - i, cy + i, // bottom left
      cx + i, cy + i, // bottom right
      tft.color565(0, 0, i));
unsigned long testFilledTriangles() {
  int           i, cx = tft.width()  / 2 - 1,
  start = micros();
  for(i=min(cx,cy); i>10; i-=5) {
    start = micros();
    tft.fillTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
      tft.color565(0, i, i));
    tft.drawTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
      tft.color565(i, i, 0));
  return t;
unsigned long testRoundRects() {
  int           w, i, i2,
  w     = min(tft.width(), tft.height());
  start = micros();
  for(i=0; i<w; i+=6) {
    i2 = i / 2;
    tft.drawRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(i, 0, 0));
unsigned long testFilledRoundRects() {
  int           i, i2,
  start = micros();
  for(i=min(tft.width(), tft.height()); i>20; i-=6) {
    i2 = i / 2;
    tft.fillRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(0, i, 0));
Ak by niekto vedel. Ďakujem
Re: Príklad pre 2,4" dotykový displej chyba kompilácie
Příspěvek od kiRRow » 05 črc 2022, 07:47
Problém bude v nějaké knihovně, která používá další knihovnu wire.h ... něco se tam někde snaží ke konstantě přistupovat jako k proměnné
Matko
Příspěvek od Matko » 06 črc 2022, 10:50
A to je hotový príklad z arduino, ktorý by nemal mať žiadne chyby.
Batata
Příspěvek od Batata » 06 lis 2022, 06:49
Myslím, že chyba není ve sketchi jako takovém, ale v kódu knihovny Adafruit_I2CDevice. Chyba, která zastavila kompilaci, je vypsaná o pár řádků výše.
Diego
Příspěvek od Diego » 06 lis 2022, 08:51
Překladač by asi chtěl tuhle knihovnu
Zkus pridat na zacatek ke knihovnam
#include <WireSlave.h>
Treba to pomuze
https://michald.eu - Můj web
