Zapis hodnoty do DB
Kony
Zapis hodnoty do DB
Příspěvek od Kony » 15 zář 2020, 21:36
Ahoj, snažím se zapsat změnu do logu do DB
v arduinu mám :
#include <SPI.h>
#include <UIPEthernet.h> // Used for Ethernet
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0x78, 0xEE  };
unsigned long cas = 0;
// ***************EDITACE *********************
// ********NUTNO DODRŽET ADRESU SOUBORU *******
// ********/reset1.php reset2.php *******
// **** NASTAVENI SITE****
IPAddress ip(192, 168, 1, 82);      //IP ADRESA
IPAddress gateway(192, 168, 1, 1);  // VYCHOZI BRANA
IPAddress subnet(255, 255, 255, 0); // MASKA
IPAddress dnServer(8, 8, 4, 4);     // DNS
int ID_MODULU = 2;
char serverName[] = "xxx.eu"; // webserver
EthernetClient client;
  pinMode(4, OUTPUT);
  Ethernet.begin(mac, ip, dnServer, gateway, subnet);
  Serial.print("ip-");
  Serial.println( Ethernet.localIP());
  Serial.print("Subnet mask-");
  Serial.println( Ethernet.subnetMask());
  Serial.print("Gateway-");
  Serial.println( Ethernet.gatewayIP());
  Serial.print("DNS-");
  Serial.println( Ethernet.dnsServerIP());
  if (millis() - cas >= 6000 || cas == 0) {
    cas = millis();
    if (client.connect(serverName, 80)) {  //starts client connection, checks for connection
      client.print("GET http://xxx.eu/reset");
      client.print(ID_MODULU);
      client.println(".php HTTP/1.0");
      client.println("Host: xxx.eu");
      client.println();
      while (client.connected()) {
     //   Serial.println(line); //ak chceme vypísať HTTP header
        if (line == "\r") {
      Serial.println("Nacitany payload response:");
      Serial.println(line); //odpoveď webservera - naše dáta
      if(line=="0"){
        digitalWrite(4, LOW);
        client.print("GET http://xxx.eu/logger.php?text=Čidlo číslo ");
        client.println(" vypnuto");
        client.println("Host: kxxx.eu");
        client.println();
        else if(line=="1"){
        digitalWrite(4, HIGH);
        client.println(" zapnuto");
        client.println();
      Serial.println("Pripojenie na webserver sa nepodarilo");
    client.stop();
a v php :
<?php
        $server = "localhost";
        $user = "kony";
        $pass = "heslo";
        $db = "jirka";
                $datum = StrFTime("%Y-%m-%d_%H:%M:%S", Time());
                if($mysqli && isset($_GET['text'])){ //pokud GET obsahuje 'hodnota', pokračuj
                $text = sanitize($_GET['text']);
                $sql = "INSERT INTO log (text, time) VALUES ('".$text."', '".$datum."')"; //sestavení SQL
                $doSql = $mysqli->query($sql); //vykonání SQL
                if($doSql){ //test úspěchu
                        echo 'Zápis byl úspěšný';
                        echo $datum;
                else{
                        echo 'Něco se nepovedlo';
                        echo $datum;
        else{
                echo "Neco je špatně";
        function sanitize($input){ //ořízne řetězec
                $input = htmlspecialchars($input);
                $input = htmlentities($input);
                $input = strip_tags($input);
                $input = trim($input);
                return $input;
DB :
time : Timestamp
text : prosty text
a ani zaboha nemůžu přijít co je špatně
mart-in
Re: Zapis hodnoty do DB
Příspěvek od mart-in » 15 zář 2020, 22:21
Zdravím,
a co to teda dělá nebo nedělá?
Po zběžném rychlo přečtení tvého kódu mi tohle přijde podezřelé, používáš tam českou diakritiku a navíc mezery.
EDIT:
To "k" tam má být?
Kony
Příspěvek od Kony » 16 zář 2020, 08:00
Zkousel jsem to i bez diakritiky, bez mezer a je to samy...
ad client.println("Host: kxxx.eu");
Tohle nevad, to jsem umazaval manualne domenu, takze v originale patri jina
Příspěvek od pavel1tu » 16 zář 2020, 11:19
A jen PHP
http://xxx.eu/logger.php?text=blablabla
ti to do databáze zapíše ?
Kony
Příspěvek od Kony » 16 zář 2020, 11:35
ano to zapise spravne vcetne casu
Příspěvek od KamilV » 16 zář 2020, 13:27
Nezdá se mi ta GET hlavička. Zkus to takto:
client.print("GET /logger.php?text=Čidlo číslo ");
Příspěvek od martinius96 » 16 zář 2020, 23:43
Diakritika by nutne nemusel byť problém, ale ten request nemáš URL encoded...
Máš tam medzery, ktoré musíš nahradiť enkódovaným reťazcom %20 (ktorý sa používa pre medzery).
Ten request, ktorý posielaš na stránku v takomto zápise, ako máš tam pošle /logger.php?text=Čidlo a ďalšie znaky webserver nenačíta, preto sa ti aj ten request vlastne rozbije, nakoľko ho nenačíta celý správne s ukončovacími znakmi a nespracuje sa to korektne...
Takže napr. by mohlo fungovať toto:
client.print("GET /logger.php?text=Čidlo%20číslo%20");
client.println("%20zapnuto");
Na strane webservera ti to načíta teraz ako - po spracovaní GET premennej:
Čidlo číslo 2 zapnuto.
Môžeš si to vypísať aj cez var_dump(); a načítať to spätne z response webservera, aby si si overil, čo webserver reálne načítal.
Taktiež si jedno spojenie ukonč predtým, ako robíš nové...
Kony
Příspěvek od Kony » 21 zář 2020, 21:00
Tak jsem prisel na to, ze jak jsem to chtel udelat tak je to naprd....
Chtel jsem aby arduino zapisovalo do DB zmeny hodnot stavu na PINu... ale jen ty zmeny. A pokud to pouziji takto, tak to zapisuje kazdou sekundu stav... chtel jsem mit takovy LOG zmen udalosti. Abych mel kontrolu, ze se ta zmena provedla.
Příspěvek od KamilV » 21 zář 2020, 22:36
Je přeci jen a jen na Tobě, kdy ten GET zavoláš. Tak si udržuj v prom. poslední stav pinu a pokud se změní, vytvoř GET request a do prom. si poznač nový stav pinu.
Kony
Příspěvek od Kony » 24 zář 2020, 10:14
nyní to mám takto :
    cas = millis();
      client.print("GET http://xxx/jirka/reset");
      client.println("Host: xxx");
      client.println();
        if (line == "\r") {
      if(line=="0"){
        if(client.connect(serverName, 80)){
        client.print("GET http://xxx/jirka/logger.php?text=Cidlo%20");
        client.println("%20vypnuto");
        client.println("Host: xxxx");
        client.println();
        else if(line=="1"){
        client.print("GET http://xxxx/jirka/logger.php?text=Cidlo%20");
        client.println("Host: xxxxxx");
        client.println();
    else {
    client.stop();
ale to mi ukládá pokaždé kontrole....
Uživatelé prohlížející si toto fórum: Semrush [Bot] a 5 hostů
