NodeMCU a 2 x DHT22
Kony
NodeMCU a 2 x DHT22
Příspěvek od Kony » 05 čer 2020, 16:46
snažím se na NodeMCU rozchodit dvě teplotní čidla..
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include "DHT.h"
// Uncomment one of the lines below for whatever DHT sensor type you're using!
//#define DHTTYPE DHT11   // DHT 11
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
#define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
/*Put your SSID & Password*/
const char* ssid = "Kony";  // Enter SSID here
const char* password = "xxxxxxxxx";  //Enter Password here
ESP8266WebServer server(80);
// DHT Sensor
#define DHTPin1 D1
#define DHTPin2 D2
// Initialize DHT sensor.
DHT dht(DHTPin1, DHTTYPE);
DHT dht2(DHTPin2, DHTTYPE);
float Temperature;
float Temperature2;
  delay(100);
  pinMode(DHTPin1, INPUT);
  pinMode(DHTPin2, INPUT);
  dht.begin();
  dht2.begin();
  Serial.println("Connecting to ");
  Serial.println(ssid);
  //connect to your local wi-fi network
  WiFi.begin(ssid, password);
  //check wi-fi is connected to wi-fi network
  Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected..!");
  Serial.print("Got IP: ");  Serial.println(WiFi.localIP());
  server.on("/", handle_OnConnect);
  server.onNotFound(handle_NotFound);
  server.begin();
  Serial.println("HTTP server started");
  server.handleClient();
void handle_OnConnect() {
 Temperature = dht.readTemperature();
 Temperature2 = dht2.readTemperature();
 server.send(200, "text/html", SendHTML(Temperature, Temperature2));
void handle_NotFound(){
  server.send(404, "text/plain", "Not found");
String SendHTML(float Temperature,float Temperature2){
  String ptr = "<!DOCTYPE html> <html>\n";
  ptr +="<head><meta charset=\"UTF-8\" name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=no\">\n";
  ptr +="<link href=\"https://fonts.googleapis.com/css?family=Open+Sans:300,400,600\" rel=\"stylesheet\">\n";
  ptr +="<title>ESP8266 Weather Report</title>\n";
  ptr +="<style>html { font-family: 'Open Sans', sans-serif; display: block; margin: 0px auto; text-align: center;color: #333333;}\n";
  ptr +="body{margin-top: 50px;}\n";
  ptr +="h1 {margin: 50px auto 30px;}\n";
  ptr +=".side-by-side{display: inline-block;vertical-align: middle;position: relative;}\n";
  ptr +=".humidity-icon{background-color: #3498db;width: 30px;height: 30px;border-radius: 50%;line-height: 36px;}\n";
  ptr +=".humidity-text{font-weight: 600;padding-left: 15px;font-size: 19px;width: 160px;text-align: left;}\n";
  ptr +=".humidity{font-weight: 300;font-size: 60px;color: #3498db;}\n";
  ptr +=".temperature-icon{background-color: #f39c12;width: 30px;height: 30px;border-radius: 50%;line-height: 40px;}\n";
  ptr +=".temperature-text{font-weight: 600;padding-left: 15px;font-size: 19px;width: 160px;text-align: left;}\n";
  ptr +=".temperature{font-weight: 300;font-size: 60px;color: #f39c12;}\n";
  ptr +=".superscript{font-size: 17px;font-weight: 600;position: absolute;right: -20px;top: 15px;}\n";
  ptr +=".data{padding: 10px;}\n";
  ptr +="</style>\n";
  ptr +="</head>\n";
  ptr +="<body>\n";
   ptr +="<div id=\"webpage\">\n";
   ptr +="<h1 style=\"font-size : 60px\">Teploty u bazénu</h1>\n";
   ptr +="<div class=\"data\">\n";
   ptr +="<div class=\"side-by-side temperature-icon\">\n";
   ptr +="<svg version=\"1.1\" id=\"Layer_1\" xmlns=\"http://www.w3.org/2000/svg\" xmlns:xlink=\"http://www.w3.org/1999/xlink\" x=\"0px\" y=\"0px\"\n";
   ptr +="width=\"9.915px\" height=\"22px\" viewBox=\"0 0 9.915 22\" enable-background=\"new 0 0 9.915 22\" xml:space=\"preserve\">\n";
   ptr +="<path fill=\"#FFFFFF\" d=\"M3.498,0.53c0.377-0.331,0.877-0.501,1.374-0.527C5.697-0.04,6.522,0.421,6.924,1.142\n";
   ptr +="c0.237,0.399,0.315,0.871,0.311,1.33C7.229,5.856,7.245,9.24,7.227,12.625c1.019,0.539,1.855,1.424,2.301,2.491\n";
   ptr +="c0.491,1.163,0.518,2.514,0.062,3.693c-0.414,1.102-1.24,2.038-2.276,2.594c-1.056,0.583-2.331,0.743-3.501,0.463\n";
   ptr +="c-1.417-0.323-2.659-1.314-3.3-2.617C0.014,18.26-0.115,17.104,0.1,16.022c0.296-1.443,1.274-2.717,2.58-3.394\n";
   ptr +="c0.013-3.44,0-6.881,0.007-10.322C2.674,1.634,2.974,0.955,3.498,0.53z\"/>\n";
   ptr +="</svg>\n";
   ptr +="</div>\n";
   ptr +="<div class=\"side-by-side temperature-text\">Teplota vzduchu</div>\n";
   ptr +="<div class=\"side-by-side temperature\">";
   ptr +=(int)Temperature;
   ptr +="<span class=\"superscript\">°C</span></div>\n";
   ptr +="</div>\n";
   ptr +="<svg version=\"1.1\" id=\"Layer_2\" xmlns=\"http://www.w3.org/2000/svg\" xmlns:xlink=\"http://www.w3.org/1999/xlink\" x=\"0px\" y=\"0px\"\n";
   ptr +="</svg>\n";
   ptr +="</div>\n";
   ptr +="<div class=\"side-by-side temperature-text\">Teplota vody</div>\n";
   ptr +=(int)Temperature2;
   ptr +="</div>\n";
   ptr +="<span class=\"superscript\">%</span></div>\n";
   ptr +="</div>\n";
  ptr +="</div>\n";
  ptr +="</body>\n";
  ptr +="</html>\n";
  return ptr;
Ale ...... výsledek u prvního čidla mám dobře, ale u druhého mi to píše hodnotu 2147483647 °C a nechápu kde mám problém
Re: NodeMCU a 2 x DHT22
Příspěvek od ondraN » 05 čer 2020, 17:04
Zkus si po změření vypsat obě hodnoty, jestli jsou správně změřené, nebo je ve výpisu prohoď. Typoval bych, že komunikace s druhým čidlem skončí nějakou chybou a v proměnné je nesmysl. Může být vadné čidlo (zkusit prohodit), problém s kabeláží nebo pinem.
Kony
Příspěvek od Kony » 05 čer 2020, 17:14
Tak uz jsem nasel chybu.. na nepájivém poli byl vadná napájecí blok
