Uno Hodiny DMD
Karo88
Uno Hodiny DMD
Příspěvek od Karo88 » 26 črc 2019, 01:24
mám hodiny, ktoré zobrazujú hodiny, dátum, teplotu vnútri a vonku.
Hodiny po 5 minútach začnú preblikávať neviem nato prísť prečo.
#include <SPI.h>
#include <DMD2.h>
/*#include <DMD.h>
DMD display(2,1);
ISR(TIMER1_OVF_vect)
    display.refresh();
//#include <fonts/hodiny10m2.h>
//#include <fonts/hodiny11m2.h>
#include <fonts/hodiny12m2.h>
//#include <fonts/Arial_Black_16.h> //vyska 12 sirka10
//#include <fonts/hodiny2.h>    //hodiny dva tenke upravit rohy
//#include <fonts/hodiny6.h>    //je hotovy vyska 14 bodov
//#include <fonts/hodiny3.h>    //vyska 16 bodov
#include <fonts/hodiny4.h>    //zatial ok vyska 16 bodov
//#include <fonts/SystemFont5x7.h>
//#include <fonts/hodiny5.h>
//#include <fonts/hodiny7tenke1.h>
#define DEBUG 0
// pre uno ak sa pouzova SoftDMD plati aj pre megu
  #define DMD_PIN_NOE 9
  #define DMD_PIN_A 6
  #define DMD_PIN_B 7
  #define DMD_PIN_SCK 8
  #define DMD_PIN_CLK 13  //sck
  #define DMD_PIN_R 11    //miso
//plati pre megu  ak sa pouziva SPIDMD
/*#define DMD_PIN_NOE 9
#define DMD_PIN_A 6
#define DMD_PIN_B 7
#define DMD_PIN_CLK 52 //sck
#define DMD_PIN_R 51   //miso
#define DISPLAYS_WIDE 2
#define DISPLAYS_HIGH 1
//SoftDMD dmd(DISPLAYS_WIDE,DISPLAYS_HIGH);
SPIDMD dmd(DISPLAYS_WIDE, DISPLAYS_HIGH, DMD_PIN_NOE, DMD_PIN_A, DMD_PIN_B, DMD_PIN_SCK);
//SoftDMD dmd(DISPLAYS_WIDE, DISPLAYS_HIGH, DMD_PIN_NOE, DMD_PIN_A, DMD_PIN_B, DMD_PIN_SCK, DMD_PIN_CLK, DMD_PIN_R);
unsigned long previousMillis = 0 , iinterval = 1000;
int addsehen = 1;
int cle_a, cle_b;
String reserialData;
String hodMinu = "0:00";
String denMesi = "12.12.18";
String tepStup1 = "-22°C";
String tepStup2 = "-22°C";
String cistyznak = "<";
  /*display.setBrightness(map(100, 0, 100, 0, 255)); //jas max255
  display.setFont(hodiny12m2);
  display.drawText(0, 0, F("00:00"));
  dmd.selectFont(hodiny12m2);
  dmd.begin();
  dmd.setBrightness(map(100, 0, 100, 0, 255)); //jas max255  dmd.setBrightness(80);
  dmd.drawString(17, 0, "00:00");
  //DMDFrame current_generation(dmd);
  // jas dmd fotorezistor
  //smartdelay(250);//smartdelay(1000);
  reserialData = Serial.readStringUntil('\r');//Serial2.readString(); //22:22;22.22.22;-25;25;1;
  Serial.println("reserialData");
  Serial.println(reserialData);
  //hodMinu = sgetValue(reserialData, ';', 0);
  //denMesi = sgetValue(reserialData, ';', 1);
  //tepStup1 = sgetValue(reserialData, ';', 2);
  //tepStup2 = sgetValue(reserialData, ';', 3);
  //jeSignalgps(sgetValue(reserialData, ';', 4).toInt());
  if (currentMillis - previousMillis > iinterval) {
    //iinterval = 1500;
    addsehen++;
  Serial.print("Prepinac switch");
  Serial.println(addsehen);
  switch (addsehen) {
    case 1: //hodiny      //10:01      // 1:01
      clerdmdPom(1);//cle_a = 1;
      iinterval = 40000; //40sek
      hodMinu = hodCisty(hodMinu);
      //Serial.print("hodMinu");
      Serial.println(hodMinu);
      //display.drawText(15, 0, "00:00");
      //display.drawText(15, 0, hodCisty(hodMinu));
      //hodMinu = "00:00";
      dmd.drawString(15, 0, hodMinu);   //dmd.drawString(15, 0, hodCisty(hodMinu));
    case 2: //datum      //12.12      // 1.1.      // 2.10      //10.1.
      //cle_a = 2;
      iinterval = 10000; //10sek
      //Serial.print("denMesi");
      Serial.println(denMesi);
      //Serial.println(denMesi.length());
      int xpor;
      //denMesi = "10.10.19";
      if (denMesi.length() == 8) {
        xpor = 5; //61 61 21 61 61 21 61 6
        //8  8  4  8  8  4  8  8
      } else if (denMesi.length() == 7) {
        xpor = 9; //61 21 61 61 21 61 6
        clerdmdPom(2);//cle_a = 2;
      } else if (denMesi.length() == 6) {
        xpor = 13; //61 21 61 21 61 6
        clerdmdPom(-2);//cle_a = -2;
      } else if (denMesi.length() < 6) {
        denMesi = "99.99.99";
        xpor = 5; //61 21 61 21 61 6
        clerdmdPom(-3);//cle_a = -3;
        clerdmdPom(-4);//cle_a = -4;
      //display.drawText(xpor, 0, denMesi);
      dmd.drawString(xpor, 0, denMesi);
    case 3: //teplota, vlhkost      //-10°C      // -1°C      // 20°C      //  5°C
      clerdmdPom(3);//cle_a = 3;
      Serial.print("tepStup1");
      Serial.println(tepStup1);
      //display.drawText(30, 0, teplota_str(tepStup1.toInt()));
      //display.drawText(0, 0, "IN");
      dmd.drawString(0, 0, "IN");
      dmd.drawString(30, 0, teplota_str(tepStup1.toInt()));
    case 4: //teplota, vlhkost      //-10°C      // -1°C      // 20°C      //  5°C
      clerdmdPom(4);//cle_a = 3;
        Serial.print("tepStup2");
        Serial.println(tepStup2);
        //display.drawText(0, 0, "OUT");
        //display.drawText(30, 0, teplota_str(tepStup2.toInt()));
        dmd.drawString(0, 0, "OUT");
        dmd.drawString(30, 0, teplota_str(tepStup2.toInt()));
    case 5:
    case 6:
      addsehen = 1;
  //iinterval = 3000;//zakomentovat potom na testovnie
String hodCisty(String h) {
  if (h.length() < 5) { //1:23
    return cistyznak + h; //prazdny znak
  return h;
void clerdmdPom(int iic) {
  if (iic != cle_b) {
    cle_b = iic;
    //display.clear();//
    dmd.clearScreen(); //dmd.clearScreen();
    Serial.println("CLEAN");
String teplota_str(int iia) {
  if (iia > -1 && iia < 10 ) { //5
    return cistyznak + cistyznak + String(iia) + "'C";
  if (iia > 9 ) { //22
    return cistyznak + String(iia) + "'C";
  if (iia < 0 && iia > -10 ) { //-5
  if (iia < -9) { //-12
    return String(iia) + "'C";
  return "";
void jeSignalgps(int ddv) {
  if (ddv==0) { //if(!gps.date.isValid() &&  !gps.time.isValid()){
    //display.setPixel(31,15, 1); //pravo dole
    dmd.setPixel(31, 15, GRAPHICS_ON); //pravo dole
String sgetValue(String data, char separator, int index)
  int found = 0;
  int strIndex[] = {0, -1};
  int maxIndex = data.length()-1;
  for(int i=0; i<=maxIndex && found<=index; i++){
    if(data.charAt(i)==separator || i==maxIndex){
        found++;
        strIndex[0] = strIndex[1]+1;
        strIndex[1] = (i == maxIndex) ? i+1 : i;
  return found>index ? data.substring(strIndex[0], strIndex[1]) : "";
String getStringPartByNr(String data, char separator, int index)
  // spliting a string and return the part nr index
  // split by separator
  int stringData = 0;        //variable to count data part nr
  String dataPart = "";      //variable to hole the return text
  for (int i = 0; i < data.length() - 1; i++) { //Walk through the text one letter at a time
    if (data[i] == separator) {
      //Count the number of times separator character appears in the text
      stringData++;
    } else if (stringData == index) {
      //get the text when separator is the rignt one
      dataPart.concat(data[i]);
    } else if (stringData > index) {
      //return text and stop if the next separator appears - to save CPU-time
      return dataPart;
  //return text if this is the last part
  return dataPart;
Re: Uno Hodiny DMD
Příspěvek od pavel1tu » 26 črc 2019, 06:56
Vítej Karolko, (sorry, musel jsem - pochopí jen ti co byli se mnou teď na vodě).
Bylo by dobré uvést základní HW:
- Arduino
- display (DMD je pár druhů), velikosti, různé IO (řadiče)
A hlavně odkaz na knihovnu, doufám že jsi použil originál a ne nějaký klon co někdo upravil (to si jen tak říkám pro sebe).
Vyzkoušej Serial dát na nějakých 115000 a více - jestli to nezdržuje, máš ho tam sice jen asi 10x nebo tak.
PS: Chci si k Vánocům nadělit stavbu s velkým DMD displejem, tak kolem toho trochu našlapuji, už jsem vyčetl, že je potřeba na velký display buď rychlejší "Arduino" (nebo něco jiného), čistý kod a hlavně nesprzněnou knihovnu, kterou si někdo ohnul jen na svůj display a své potřeby.
Nemám ale žádné zkušenosti (jen co jsem vyčetl za řešené problémy), a jsem rád že se to tu vyřeší - budu to mít jednodušší
Karo88
Re: Uno Hodiny DMD
Příspěvek od Karo88 » 26 črc 2019, 11:56
HW -Arduino UNO,
DMD -32x16 jeden panel, mám dva paneli vedľa seba
origo knižnice z Freetronics
PS: ak budeš stavať tak dobrý je aj wemos mne zvládal 13panelov
Re: Uno Hodiny DMD
Příspěvek od pavel1tu » 26 črc 2019, 18:22
Tak to by mělo být v pohodě, to je málo LED, ale pro jistotu testni jen jeden panel - četl jsem o problémech s více panely (ale to psal o 4ks). Já uvažuji o 4 těchto panelech, ale zatím nevím o projektu co by neměl s tímto problémy.
Tu rychlost Serial zvedni, nebo zakomentuj vše co ti jde na Serial (na zkoušku) - mám vyzkoušeno, že Arduino když obsluhuje Serial, nic nedělá - je to jako by jsi dal Delay()
Jinak mne nic nenapadá.
Pak jedině vyzkoušet nějaký příklad z knihovny a pokud se ten nebude zadrhávat (že by zadrhávala ATMega) tak musíš pohledat v kodu.
Kdybych to měl jak otestovat, ale nemám :(
