Wifi hodiny esp8266 + TM1650 + 8025T
johnyhol
Re: Wifi hodiny esp8266 + TM1650 + 8025T
Příspěvek od johnyhol » 20 bře 2023, 18:46
Tak jsem se k tomu dostal až teď a musím potvrdit že to funguje! Paráda, díky moc.
Tady je tedy funkční kód kdyby se to někomu hodilo:
#include <NTPClient.h>
#include <WiFiUdp.h>
#include <OneWire.h>
#include <CayenneMQTTESP8266.h>
#include <Wire.h>
#include <TM1650.h>
TM1650 d;
#define Teplota 13 // DS18B20
#define Dvere 12 // Dvere
#define Rele 14 // Rele
OneWire oneWire(Teplota);
char username[] = "";
char password[] = "";
char clientID[] = "";
const char* ssid = "";
const char* wifipassword = "";
const long utcOffsetInSeconds = 3600;
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP, "europe.pool.ntp.org", utcOffsetInSeconds);
void setup(){
  Wire.begin();
  d.init();
  timeClient.begin();
  pinMode(Dvere, INPUT);
  pinMode(Rele, OUTPUT);
  digitalWrite(Rele, LOW);
  Cayenne.begin(username, password, clientID,  ssid, wifipassword);
  sensors.begin();
void loop(){
  char waktu[5];
  timeClient.update();
  sprintf(waktu, "%02d%02d", timeClient.getHours(), timeClient.getMinutes());
  d.displayOn();
  d.setBrightness(1);
  d.displayString(waktu);
  for (int i = 1; i<2; i++) {
    d.setDot(i,true);
  Cayenne.loop(); //spusteni Cayenne
//--Teplota--//
CAYENNE_OUT(1){
  // Send the command to get temperatures.
  Serial.print("Teplota: ");
  Serial.print(sensors.getTempCByIndex(0));
  Serial.println("*C");
  // This command writes the temperature in Celsius to the Virtual Channel.
  Cayenne.celsiusWrite(1, sensors.getTempCByIndex(0));
//--Dvere--//
CAYENNE_OUT(2){
 if (digitalRead(Dvere) == LOW) {
     Cayenne.virtualWrite(2, 1, "digital_sensor", "d");
     Serial.println("Dvere: zavreno...");
  else {
     Cayenne.virtualWrite(2, 0, "digital_sensor", "d");
     Serial.println("Dvere: otevreno...");
//--Rele--//
CAYENNE_IN(3){
  // Write value to turn the relay switch on or off. This code assumes you wire your relay as normally open.
  //if (getValue.asInt() == 1) { //pokud je Cayenne zapnute sepni rele
    if (getValue.asInt() == 1 && digitalRead(Dvere) == HIGH) { //pokud je Cayenne zapnute a dvere zavrene sepni rele
    digitalWrite(Rele, HIGH);
    Cayenne.virtualWrite(3, 1, "digital_sensor", "d");
  else {
    Cayenne.virtualWrite(3, 0, "digital_sensor", "d");
//--Wi-Fi--//
CAYENNE_OUT_DEFAULT(){
Cayenne.virtualWrite(4, WiFi.RSSI()); //zobrazeni signalu WiFi
Příspěvek od kiRRow » 20 bře 2023, 20:03
není zač, jsem rád, že funguje. Jinak ten chatGPT openAI není marný, já bych si na to udělal funkci co by vracela řetězec. Pro mne je to rychlejší než hledat něco co to udělá za mne, ale jak vidíš, tak ještě rychlejší bylo se zeptat někoho chytřejšího než já :-D
