Pomoc s chybami v programu
Spider 1970
Re: Pomoc s chybami v programu
Příspěvek od Spider 1970 » 14 lis 2019, 12:07
Spider 1970 píše:
14 lis 2019, 12:05
Tady je ten odkaz na ten kod [https://petermobbs.wordpress.com/2014/1 ... ocus-rail/][/url].První jsem to našel na you tube,líbilo se mi to a tak jsem si nakoupil i věci a ted tohle . :evil:
JEŠTĚ PŘIDÁVÁM ODKAZ NA YOU TUBE TAM JE VIDĚT CO TO MÁ DĚLAT
https://www.youtube.com/watch?v=3wgo0pdXmD0&t=248s
Příspěvek od pavel1tu » 14 lis 2019, 18:07
Ten WordPress mu to zprasil
v diskusi pod tím je asi opravený kod
vyzkoušíš jej ?
Zkompilovat mi to šlo, ale nemám sil zkoumat co to má dělat, musel jsem do hospody a po těch pivech ....
  New stacker ver 1.3 20160907
  Based on original by Peter Mobbs (thankyou)
  Important plug in camera AFTER switch on & initialization
  Modifications by David Marsden to suit ROBOT LCD shield
  Delay time fixed at 5 seconds
  camera pin changed to 0
  enable pin changed to 1
  dir pin changed to 2
  drive (step) changed to 3
  flash not used (always set camera to X sync)
  delay in line 430 changed from 100 to 1000
  Changed jog speeds - slow = 1600, fast = 800
  Changed direction of fast jog, case 1 is -, case 3 is +
  Speed in stack movement changed to 1600
  Delay between shutter high & low changed to 1000
  Distance input changed to mm
  Accumulators changed to symetrical for & rev, 10 fast & 1 slow
  Directions changed to suite position on bread board,
  Various tidy ups
#include <LiquidCrystal.h>
LiquidCrystal lcd( 8, 9, 4, 5, 6, 7 ); //Pins used by LCD
// Global variables
int adc_key_val[5] ={50, 200, 400, 600, 800 }; // These are the values returned by the adc for different button presses
int NUM_KEYS = 5;
int adc_key_in;
int key=-1;
int oldkey=-1;
int jog_speed;
int rail_direction = 0;
//Pins that will be used to control the rail and the camera
// changed from original to give tidy cable run from shield to easydriver board
int camera_pin = 0;
int enable_pin = 1;
int dir_pin = 2;
int drive_pin = 3;
//int flash_pin = 16;
int number_photos =0;
int distance = 0;
int delay_time = 6000; //miliseconds.
int k = 0;
int keep[4] ={0,0,0,0}; // Only really need four members to array because not using zero member!
START-UP, display setup, signs on, gives basic info etc.
Set motor off & shutter off
pinMode(enable_pin,OUTPUT);
digitalWrite(enable_pin, HIGH);
//set camera pin low (shutter off)
pinMode(camera_pin,OUTPUT);
digitalWrite(camera_pin, LOW);
Sign-on
lcd.begin(16, 2);
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" MadBoffin Labs ");
lcd.setCursor(0,1);
lcd.print(" 5th Oct 2014 ");
delay(1500);
Program name
lcd.clear();
lcd.setCursor(0,0);
lcd.print("  STEPPER RAIL  ");
delay (1500);
Instructions
//for (char k=0;k<16;k++)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Use buttons to ");
lcd.setCursor(0,1);
lcd.print("change values ");
delay (1500);
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" To end entries ");
lcd.setCursor(0,1);
lcd.print(" press <Select> ");
delay (1500);
lcd.clear();
// Jog or Stack menu - never ending loop
digitalWrite(enable_pin, HIGH); // motor off at return from stacker or  jogger
lcd.print(" Stack or Jog? ");
lcd.setCursor(0,1);
lcd.print(" L=Stack, R=Jog ");
which_button(key);
switch (key){
case(3):
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Calling Stacker ");
delay(1500);
digitalWrite(enable_pin, LOW); // motor on
stacker();
break;
case(0):
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" Calling Jogger ");
delay(1500);
digitalWrite(enable_pin, LOW); //motor on
jogger();
break;
//STACKER routine gets button presses and adds up values ascribed to them to give an accumulated answer
void stacker()
int stop_flag_dir_stack = -1;
int stop_flag=1;
int long accumulator = 0;
int function = 1;
rail_direction = 0;
number_photos = 0;
distance = 0;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Camera away -R");
lcd.setCursor(0,1);
lcd.print("Camera toward -L");
//Get a keypress and debounce it.
do{
which_button(key);
switch (key){
case 3: //left button
rail_direction = -1;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Camera moving ");
lcd.setCursor(0,1);
lcd.print(" Towards ");
stop_flag_dir_stack = 1;
break;
case 0: //right button
rail_direction = 1;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" Away ");
break;
}while (stop_flag_dir_stack != 1);
do{
lcd.clear();
lcd.setCursor(0,0);
switch(function){
case 1:
lcd.print("No. of photos? ");
break;
case 2:
lcd.print("Distance in mm? ");
break;
which_button(key);
// Turn button presses into values
switch (key){
case 0:
accumulator = accumulator - 1;
break;
case 3:
accumulator = accumulator + 1;
break;
case 1:
accumulator = accumulator + 10;
break;
case 2:
accumulator = accumulator - 10;
break;
case 4:
stop_flag = stop_flag+1;
keep[function] = accumulator;
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print("Using: ");
lcd.print(keep[function]);
function = function + 1;
accumulator = 0;
break;
// Sets lower limit
if (accumulator <= 0){
accumulator=0;
if (function != 4){
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print(accumulator);
delay(100);
}while (stop_flag <=2);
number_photos = keep[1];
keep[1] =0;
distance = keep[2];
distance=distance*100;
keep[2] =0;
motor_driver(rail_direction, number_photos, distance, delay_time);
// WHICH BUTTON routine - returns debounced key
int which_button (int a)
adc_key_in = analogRead(0);
key = get_key(adc_key_in);
if (key != oldkey){
delay(30);
oldkey=key; // position?
return (key);
// Convert ADC value from A0 to key number/button press
int get_key(unsigned int input)
int k;
for (k = 0; k < NUM_KEYS; k++)
if (input < adc_key_val[k])
return k;
if (k >= NUM_KEYS)k = -1; // No valid key pressed
return k;
 JOGGER routine - gets buttons and attributes values to them.
 Then call jog_motor routine to move the rail.
 'Up' and 'Down' buttons are fast jog away & towards
 'Left' and 'Right' buttons will be slow jog away and towards.
void jogger()
// First tell user what the buttons do
int jog_stop_flag = 0;
jog_speed =0;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("L=Towards R=Away");
lcd.setCursor(0,1);
lcd.print("U=Towards D=Away");
delay(3000);
/*lcd.clear();
lcd.setCursor(0,0);
lcd.print(" Use <Select> ");
lcd.setCursor(0,1);
lcd.print("to exit to menu ");
*///delay(1500);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("OK ready to jog!");
//now get key presses
do{
which_button(key);
// Now get speed and direction for jog and call jog_motor
switch (key){
case 0://Slow
jog_speed = - 3200;
jog_motor(jog_speed);
break;
case 3://Slow
jog_speed = + 3200;
break;
case 1://Fast
jog_speed = + 800;
break;
case 2://Fast
jog_speed = - 800;
break;
case 4:
// stop jog
jog_stop_flag = 1;
break;
}while (jog_stop_flag != 1);
 JOG MOTOR routine - jogs the motor via EasyDriver
int jog_motor(int a)
pinMode(dir_pin,OUTPUT);
pinMode(drive_pin,OUTPUT);
pinMode(camera_pin, OUTPUT);
digitalWrite(dir_pin,LOW);
digitalWrite(drive_pin,LOW);
// Set direction and then drive motor at with jog_speed microsecond delays between pulse phases
if (jog_speed <= 0){
digitalWrite(dir_pin,HIGH);
jog_speed = jog_speed * -1;
delayMicroseconds(jog_speed);
digitalWrite(drive_pin,HIGH);
  MOTOR DRIVER routine - moves the motor via EasyDriver and activates camera to produce a photo stack
  The value of [steps_per_micron] is crucial for absolute accuracy and needs to be set by moving the rail
  and seeing how far it actually travels.
  0.5 steps per micron gives 10mm movement per 10mm set
int motor_driver(int a, int b, int c, int d)
float steps_per_micron = 0.5;
long int steps_between_photos;
long int distance_between_photos;
long int total_steps;
int carry_direction;
//pinMode(flash_pin, OUTPUT);
distance_between_photos= distance/(number_photos -1);
steps_between_photos = (float)distance_between_photos / steps_per_micron; // check loss of precision!
//Display parameters###########################################
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Motion= ");
if (rail_direction == 1){
  lcd.print("Away");
if (rail_direction == -1){
  lcd.print("Towards");
lcd.clear();
lcd.setCursor(0,0);
//lcd.print("Photos= ");
lcd.print("No of photos= ");
lcd.print(number_photos);
delay (1000);
lcd.setCursor(0,1);
lcd.print("Dist = ");
lcd.print(distance/100);
lcd.print("mm");
delay (1500);
//head off in the right direction!
digitalWrite(dir_pin, LOW);
digitalWrite(dir_pin, HIGH);
//set camera_pin high - first photo is where the rail is now
//tell operator taking first photo
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Photo #: 1 ");
lcd.setCursor(0,1);
lcd.print("In stack of: ");
digitalWrite(camera_pin, HIGH);
//digitalWrite(flash_pin, HIGH);
//digitalWrite(flash_pin, LOW);
//Take subsequent photos
for (int x_count_photos = 1; x_count_photos <= number_photos-1; x_count_photos++){
//move rail position by steps_between_photos
//motor speed is set by delays...going slowly to avoid lost steps...
for(int y_count_steps = 1; y_count_steps <= steps_between_photos; y_count_steps++){
//move camer
delayMicroseconds(1600);
//Wait a while for camera to stabilise
delay(delay_time);
//Tell user which photo is being taken
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Photo #: ");
lcd.print(x_count_photos + 1);
lcd.setCursor(0,1);
// take the photo and set flash_pin high with camera_pin long enough to trigger camera
lcd.setCursor(0,1);
// End of stack
delay(2000);// so you can see the last value for photo number
//Rewind the slider to the starting point by reversing rail_direction and going back total number of steps in stack
//Warn that rewind about to take place..
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" Rewinding ");
carry_direction = rail_direction;
if (carry_direction == -1){
if (carry_direction == 1){
//digitalWrite(dir_pin, rail_direction);
total_steps = (number_photos -1) * steps_between_photos;
for (int x_count_rewind=1; x_count_rewind <= total_steps; x_count_rewind ++){
digitalWrite(drive_pin, LOW);
delayMicroseconds(800);
digitalWrite(drive_pin, HIGH);
lcd.clear();
Spider 1970
Příspěvek od Spider 1970 » 14 lis 2019, 19:44
pavel1tu píše:
14 lis 2019, 18:07
vyzkoušíš jej ?
  Various tidy ups
// Global variables
int NUM_KEYS = 5;
int adc_key_in;
int key=-1;
int oldkey=-1;
int jog_speed;
int camera_pin = 0;
int enable_pin = 1;
int dir_pin = 2;
int drive_pin = 3;
int distance = 0;
int k = 0;
Sign-on
lcd.begin(16, 2);
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
delay(1500);
Program name
lcd.clear();
lcd.setCursor(0,0);
delay (1500);
Instructions
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
delay (1500);
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
delay (1500);
lcd.clear();
lcd.setCursor(0,1);
which_button(key);
switch (key){
case(3):
lcd.clear();
lcd.setCursor(0,0);
delay(1500);
stacker();
break;
case(0):
lcd.clear();
lcd.setCursor(0,0);
delay(1500);
jogger();
break;
void stacker()
int stop_flag=1;
int function = 1;
rail_direction = 0;
number_photos = 0;
distance = 0;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
do{
which_button(key);
switch (key){
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
break;
rail_direction = 1;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
break;
do{
lcd.clear();
lcd.setCursor(0,0);
switch(function){
case 1:
break;
case 2:
break;
which_button(key);
switch (key){
case 0:
break;
case 3:
break;
case 1:
break;
case 2:
break;
case 4:
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(0,1);
accumulator = 0;
break;
// Sets lower limit
accumulator=0;
if (function != 4){
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(0,1);
delay(100);
keep[1] =0;
distance = keep[2];
keep[2] =0;
if (key != oldkey){
delay(30);
return (key);
int k;
return k;
return k;
void jogger()
jog_speed =0;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
delay(3000);
/*lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
*///delay(1500);
lcd.clear();
lcd.setCursor(0,0);
do{
which_button(key);
switch (key){
case 0://Slow
jog_speed = - 3200;
break;
case 3://Slow
jog_speed = + 3200;
break;
case 1://Fast
jog_speed = + 800;
break;
case 2://Fast
jog_speed = - 800;
break;
case 4:
// stop jog
jog_stop_flag = 1;
break;
lcd.clear();
lcd.setCursor(0,0);
  lcd.print("Away");
lcd.clear();
lcd.setCursor(0,0);
delay (1000);
lcd.setCursor(0,1);
lcd.print("mm");
delay (1500);
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
//move camer
delay(delay_time);
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.setCursor(0,1);
// End of stack
lcd.clear();
lcd.setCursor(0,0);
lcd.clear();
Jen co přijdu z rachoty domu vyzkouším. Já ti to pivo tak zavidim
Spider 1970
Příspěvek od Spider 1970 » 15 lis 2019, 00:16
Spider 1970 píše:
14 lis 2019, 19:44
pavel1tu píše:
14 lis 2019, 18:07
vyzkoušíš jej ?
  Various tidy ups
// Global variables
int NUM_KEYS = 5;
int adc_key_in;
int key=-1;
int oldkey=-1;
int jog_speed;
int camera_pin = 0;
int enable_pin = 1;
int dir_pin = 2;
int drive_pin = 3;
int distance = 0;
int k = 0;
Sign-on
lcd.begin(16, 2);
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
delay(1500);
Program name
lcd.clear();
lcd.setCursor(0,0);
delay (1500);
Instructions
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
delay (1500);
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
delay (1500);
lcd.clear();
lcd.setCursor(0,1);
which_button(key);
switch (key){
case(3):
lcd.clear();
lcd.setCursor(0,0);
delay(1500);
stacker();
break;
case(0):
lcd.clear();
lcd.setCursor(0,0);
delay(1500);
jogger();
break;
void stacker()
int stop_flag=1;
int function = 1;
rail_direction = 0;
number_photos = 0;
distance = 0;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
do{
which_button(key);
switch (key){
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
break;
rail_direction = 1;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
break;
do{
lcd.clear();
lcd.setCursor(0,0);
switch(function){
case 1:
break;
case 2:
break;
which_button(key);
switch (key){
case 0:
break;
case 3:
break;
case 1:
break;
case 2:
break;
case 4:
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(0,1);
accumulator = 0;
break;
// Sets lower limit
accumulator=0;
if (function != 4){
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(0,1);
delay(100);
keep[1] =0;
distance = keep[2];
keep[2] =0;
if (key != oldkey){
delay(30);
return (key);
int k;
return k;
return k;
void jogger()
jog_speed =0;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
delay(3000);
/*lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
*///delay(1500);
lcd.clear();
lcd.setCursor(0,0);
do{
which_button(key);
switch (key){
case 0://Slow
jog_speed = - 3200;
break;
case 3://Slow
jog_speed = + 3200;
break;
case 1://Fast
jog_speed = + 800;
break;
case 2://Fast
jog_speed = - 800;
break;
case 4:
// stop jog
jog_stop_flag = 1;
break;
lcd.clear();
lcd.setCursor(0,0);
  lcd.print("Away");
lcd.clear();
lcd.setCursor(0,0);
delay (1000);
lcd.setCursor(0,1);
lcd.print("mm");
delay (1500);
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
//move camer
delay(delay_time);
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.setCursor(0,1);
// End of stack
lcd.clear();
lcd.setCursor(0,0);
lcd.clear();
Tak to vypadá že funguje,je to jiná verze taková light,Tak se snažím dát do kupy tu předchozí.Schází tam nějaké nastavení teda spíš jsou tu nastaveny defaultně.Zítra vysvětlím,ale díky moc
Příspěvek od pavel1tu » 15 lis 2019, 06:29
Napiš mu na těch jeho stránkách
on ti pošle aktuální kod.
Co jsem koukal na jeho příspěvky - docela rychle reaguje na dotazy a tak.
Spider 1970
Příspěvek od Spider 1970 » 15 lis 2019, 13:23
pavel1tu píše:
15 lis 2019, 06:29
Tak jsem ten program asi dal dohromady. Šel jsem spát až v 6 ráno a neměl čas to vyzkoušet. Tak až přijdu z odpolední tak to vyzkousim
