Dadasys
Příspěvek
od Dadasys » 30 dub 2020, 12:52
Přeci jen je potřeba doladit jednu drobnost. Po zapnutí do sítě se motor točí bez ohledu na ldr čidlo a polohu dveří. Dumám, jak docílit toho, aby motor po zapnutí stál až do prvního čtení světla..
const int EnMotorPin = 9; // enable motor - pin 9 PWM
const int CloseDoorPin = 8; // direction close motor - pin 8
const int OpenDoorPin = 7; // direction open motor - pin 7
const int photocellPin = A0; // photocell connected to analog 0
const long eventTime_1_LDR = 20000; // 20 vteřin
unsigned long previousTime_1 = 0;
int photocellVal; // analog reading of the photocel
bool daylight = true; // daylight status
int darkthreshold = 20;
int daythreshold = 350;
int systemState = 0;
int SPEED = 220;
int bottomSwitchPin = 2; // Reed switches top and bottom of coop door
int topSwitchPin = 4;
bool topSwitchState; // true if door is up
bool bottomSwitchState; // true if door is down
pinMode(bottomSwitchPin, INPUT);
pinMode(topSwitchPin, INPUT);
pinMode(EnMotorPin, OUTPUT);
pinMode(CloseDoorPin, OUTPUT);
pinMode(OpenDoorPin, OUTPUT);
systemState = 0;
unsigned long currentTime = millis();
if ( currentTime - previousTime_1 >= eventTime_1_LDR) {
photocellVal = analogRead(photocellPin); // read inputs
previousTime_1 = currentTime;
if (photocellVal > daythreshold)
daylight = true;
if (photocellVal < darkthreshold)
daylight = false;
topSwitchState = digitalRead(topSwitchPin);
bottomSwitchState = digitalRead(bottomSwitchPin);
// read system status
if (daylight == true && topSwitchState == true)
systemState = 0; // motor stop
if (daylight == true && topSwitchState == false)
systemState = 1; // drive door up
if (daylight == false && bottomSwitchState == true)
if (daylight == false && bottomSwitchState == false)
systemState = 2; // drive door down
DispVals();
switch (systemState) {
case 0: // motor stop
digitalWrite(CloseDoorPin, LOW);
digitalWrite(OpenDoorPin, LOW);
analogWrite(EnMotorPin, 0);
break;
case 1: //drive door up
digitalWrite(OpenDoorPin, HIGH);
analogWrite(EnMotorPin, SPEED);
break;
case 2: // drive door down
digitalWrite(CloseDoorPin, HIGH);
break;
default:
break;
void DispVals()
Serial.print("topSW ");
Serial.print(topSwitchState);
Serial.print("\t");
Serial.print("botSW ");
Serial.print(bottomSwitchState);
Serial.print("\t");
Serial.print("PhotoVal ");
Serial.print(photocellVal);
Serial.print("\t");
Serial.print("daylight ");
Serial.print(daylight);
Serial.print("\t");
Serial.print("systemState ");
Serial.print(systemState);
Serial.print("\t");
if (systemState == 0)
Serial.println("\t door stopped");
if (systemState == 1)
Serial.println("\t door driving up");
if (systemState == 2)
Serial.println("\t door driving down");
Příspěvek
od kiRRow » 30 dub 2020, 13:12
V setupu, po tom co nastavíš inputy a outputy, tam musíš nastavit výstupy tak aby se ti motor netočil. Ideálně by měl provést třeba otevření a zastavit se, aby po startu byl vždy v jedné a určité poloze - jakože něco jako kalibrace.
BigSandy
Příspěvek
od BigSandy » 02 kvě 2020, 02:25
Jen jsem to tak rychlo prolit a používáš jen modul času DS3231?
Jak jsi s tým spokojený.
Já otvíraní kurníku dělal už před 5 roky take s hodinami a po roce, když jsem nacházel chrápat slepice venku to honem předělával na fotoodpor GL5528.
Přes zimu už sedi slipky v 17:30 hod v kurníku a přes leto ještě ve 20:30 litaji po zahradě
Axamith
Příspěvek
od Axamith » 02 kvě 2020, 07:49
Okrajově sleduji debatu o slepicích a pořád nechápu, proč se tady řeší časové rozsahy, i když slunce zapadá v danou dobu, pořád zde vstupuje faktor zatažené oblohy. Já bych to také řešil sledování konkrétních světelných podmínek.
Dadasys
Příspěvek
od Dadasys » 02 kvě 2020, 08:15
kiRRow píše: ↑30 dub 2020, 13:12
Zkoušel jsem nastavit podle SZ, ale pořád se točí. Zatím řeším přidáním delay v setupu..
Příspěvek
od pavel1tu » 02 kvě 2020, 12:06
Axamith píše: ↑02 kvě 2020, 07:49
Kamarád to tak měl a zrušil to,
u nás pod horama se často zatáhne na chvilku a pak zase roztáhne a stávalo se, že se dveře zavřely a slepice byly venku.
Teď z toho má "hybrida" a je spokojenější.
Příspěvek
od pavel1tu » 02 kvě 2020, 14:46
Dadasys píše: ↑02 kvě 2020, 08:15
A nepoužíváš relátka co fungují inverzně ?
Tj. když pošleš "1" relé rozepne, když "0" relé sepne ?
Dadasys
Příspěvek
od Dadasys » 02 kvě 2020, 14:50
Nemám tam žádné relé.. Jede to pres
l298n
Odesláno z mého Lenovo P2a42 pomocí Tapatalk
Příspěvek
od pavel1tu » 02 kvě 2020, 17:41
No a jak máš ten setup()
Hned po deklaraci co je výstup,
musíš tam nastavit nějaký směr, já mám směr LOW, LOW což je asi STOP a ovládací PWM na nulu - pro jistotu.
Máš to dobře zapojené ?
Tohle mám na stole, sice s jiným můstkem, mám velký motor, a funguje mi to.
https://howtomechatronics.com/tutorials ... -h-bridge/
Já tedy ještě propojil GND mezi zdroji 5/12V mám je nezávislé.
Dadasys
Příspěvek
od Dadasys » 02 kvě 2020, 20:10
Celý kód je o několik příspěvků výš. Napájí se 12V ten můstek a z něj je 5V výstup do arduina. Zapojení kdyžtak nakreslím. D
