Nahoď sem výsledek, díky ...
já se to snažím upravit, ale nemám ten RTC tak to nejde testovat
díky
ChickenDoor - V0.7
This is modified version of the original project (https://backyardpoultry.iamcountryside.com/coops/automating-a-chicken-coop-door/).
The original version calculated the time in seconds, this version calculates in minutes.
Opens and closes a linear actuator based on sunrise and sunset tables included in the program.
Time is in minutes
Uses the Timezone library (url below) to automatically adjust the time twice yearly for Daylight
Saving Time.
// Includes
#include <Arduino.h>
#include <DS1307RTC.h> //http://www.arduino.cc/playground/Code/Time
#include <Time.h> //http://www.arduino.cc/playground/Code/Time
#include <TimeLib.h>
#include <Timezone.h> //https://github.com/JChristensen/Timezone
#include <Wire.h> //http://arduino.cc/en/Reference/Wire (supplied with the Arduino IDE)
#pragma GCC diagnostic ignored "-Wwrite-strings"
// Defines
#define DEBUG
#define OPEN 0
#define CLOSED 1
#define OFF 0
#define ON 1
#define SUNRISE_DELAY (0) //x minutes delay to open
#define SUNSET_DELAY (30) // x minutes delay to close
// Sunset times in minutes after midnight for each ordinal day of the year,
// eg, Jan 1 = array index 0, etc. The times are CET and are adjusted one
// hour when DST is in effect.
// The arrays are stored in program memory because dynamic memory is not
// big enough to hold them
static const int sunsetAr[] PROGMEM = {965,966,968,969,970,971,972,973,975,976,977,979,980,981,983,984,986,987,989,990,992,993,995,996,998,1000,1001,1003,1005,1006,1008,
1009,1011,1012,1014,1016,1017,1019,1021,1023,1024,1026,1028,1029,1031,1033,1034,1036,1038,1039,1041,1043,1044,1046,1048,1049,1051,1052,1054,1056,
1057,1059,1060,1062,1064,1065,1067,1068,1070,1072,1073,1075,1076,1078,1079,1081,1083,1084,1086,1087,1089,1090,1092,1093,1095,1096,1098,1099,1101,1102,1104,
1106,1107,1109,1110,1112,1113,1115,1116,1118,1119,1121,1122,1124,1125,1127,1128,1130,1131,1133,1134,1136,1137,1139,1140,1142,1143,1145,1146,1148,1149,
1151,1152,1154,1155,1157,1158,1159,1161,1163,1164,1165,1167,1168,1170,1171,1172,1174,1175,1176,1178,1179,1180,1181,1182,1184,1185,1186,1187,1188,1189,1190,
1191,1192,1193,1194,1195,1196,1196,1197,1198,1198,1199,1200,1200,1201,1201,1202,1202,1202,1203,1203,1203,1203,1203,1203,1203,1203,1203,1203,1203,1203,
1203,1202,1202,1201,1201,1200,1200,1200,1200,1200,1200,1200,1200,1200,1200,1200,1200,1200,1200,1200,1200,1200,1200,1200,1200,1200,1200,1200,1200,1200,1200,
1200,1200,1200,1200,1200,1200,1200,1162,1159,1158,1157,1155,1153,1151,1150,1148,1146,1144,1142,1140,1138,1136,1134,1132,1130,1128,1110,1110,1110,1110,1110,
1110,1110,1110,1110,1090,1090,1090,1090,1090,1090,1090,1090,1090,1088,1086,1084,1082,1080,1078,1075,1073,1071,1069,1067,1065,1062,1060,1058,1056,1054,
1052,1050,1048,1045,1043,1041,1039,1037,1035,1033,1031,1029,1027,1025,1023,1021,1019,1017,1015,1013,1011,1009,1008,1006,1004,1002,1000,999,997,995,993,
992,990,989,987,985,984,982,981,980,978,977,975,974,973,972,970,969,968,967,966,965,964,963,962,962,961,960,959,959,958,
958,957,957,956,956,956,955,955,955,955,955,955,955,955,955,956,956,956,957,957,958,958,959,959,960,961,961,962,963,964,965};
static const int sunriseAr[] PROGMEM = {435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,
435,435,435,435,435,435,435,435,434,432,431,429,427,426,424,422,420,419,417,415,413,411,409,407,405,403,402,400,398,
396,394,392,390,387,385,383,381,379,377,375,373,371,369,367,364,362,360,358,356,354,352,350,347,345,343,341,339,360,300,300,
300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,300,298,296,294,292,290,288,286,284,282,281,279,277,275,273,
272,270,268,267,265,263,262,260,259,257,256,254,253,252,250,249,248,246,244,244,243,242,241,240,239,238,237,236,235,234,233,
233,232,232,231,230,230,229,229,229,228,228,228,228,228,228,228,228,228,228,228,228,228,229,229,229,230,230,231,231,232,
233,233,234,235,235,236,237,238,239,240,241,242,243,244,244,246,247,248,249,251,251,251,251,251,251,251,251,251,251,251,251,
251,251,251,251,251,251,251,251,251,251,270,270,270,270,270,270,270,270,270,270,294,296,297,299,300,300,300,300,300,300,300,
300,300,300,300,300,300,300,300,300,300,300,300,300,300,315,315,315,315,315,315,315,315,315,315,315,315,315,315,315,315,
330,330,330,330,330,330,330,330,330,330,330,330,330,330,330,330,330,330,330,330,330,330,330,330,331,332,394,396,397,399,401,
402,404,405,407,409,410,412,413,415,417,418,420,421,423,425,426,428,429,431,432,434,435,435,435,435,435,435,435,435,435,
435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435,435};
// Constants
const int delayTime = 1000;
const int relayOnePin = 1; // Unused
const int relayTwoPin = 7; // Door 1
const int relayThreePin = 6; // Door 2
const int relayFourPin = 4; // Lights
const int minutesPerHour = 60;
// Days of months array for ordinal calculation
static const int monthLen[] = { 31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31 };
// Globals
//Central European Time (Frankfurt, Paris, Prague)
TimeChangeRule CEST = {"CEST", Last, Sun, Mar, 2, 120}; //Central European Summer Time
TimeChangeRule CET = {"CET ", Last, Sun, Oct, 3, 60}; //Central European Standard Time
Timezone myTZ(CEST, CET);
TimeChangeRule *tcr; // pointer to the time change rule, use to get TZ abbrev
time_t utc, local;
int doorState = CLOSED;
int lightState = OFF;
// Init
int sunset = 0;
int sunrise = 0;
int minutes = 0;
// Initialize the relay pins
pinMode(relayOnePin, OUTPUT);
pinMode(relayTwoPin, OUTPUT);
pinMode(relayThreePin, OUTPUT);
pinMode(relayFourPin, OUTPUT);
#ifdef DEBUG
// Start the serial port
while (!Serial)
delay(200);
#endif
// Set the time using the RTC's time
setSyncProvider(RTC.get); // Get the time from the RTC
#ifdef DEBUG
if(timeStatus()!= timeSet) // Again, this is check the TZ lib status
Serial.println("Unable to sync with the RTC");
else
Serial.println("RTC has set the system time ");
#endif
// Door initialization based on TZ library time
utc = now();
local = myTZ.toLocal(utc, &tcr);
#ifdef DEBUG
Serial.print("Start-up time: ");
printTime(local, tcr -> abbrev);
#endif
// We have the date and time, convert it to minutes since midnight
minutes = toMinutes(hour(local), minute(local));
// Get the ordinal day of the year to use as an index into the sunset/rise arrays
int ordinalDay = ordinalDayOfYear(tmYearToCalendar(year(local)), month(local), day(local));
// Get the times adjusted for DST and open/close delay
sunrise = getAdjustedSunriseTime(ordinalDay, local);
sunset = getAdjustedSunsetTime(ordinalDay, local);
// Close or open the door, the door methods check for current state
if ((minutes > sunrise) && (minutes < sunset))
doorState = CLOSED;
openDoor();
doorState = OPEN;
closeDoor();
Serial.print(" Vychod: ");
Serial.println(sunrise);
Serial.print(" Zapad: ");
Serial.println(sunset);
Serial.print(" Aktualni: ");
Serial.println(minutes);
int sunset = 0;
int sunrise = 0;
int minutes = 0;
// Wait the current delay time
delay(delayTime);
// get current date and time
utc = now();
//Serial.print("Aktualni time: ");
//printTime(local, tcr -> abbrev);
#ifdef DEBUG
// printTime(local, tcr -> abbrev);
#endif
minutes = toMinutes(hour(local),minute(local));
// Now get the ordinal day of the year
openDoor();
closeDoor();
void openDoor()
// Is the door closed?
if (doorState == CLOSED)
#ifdef DEBUG
Serial.print("Opening door: ");
utc = now();
#endif
doorState = OPEN;
// open the door
digitalWrite(relayTwoPin, LOW);
digitalWrite(relayThreePin, HIGH);
return;
void closeDoor()
// Is the door open?
if (doorState == OPEN)
#ifdef DEBUG
Serial.print("Closing door: ");
utc = now();
#endif
doorState = CLOSED;
// close the door
digitalWrite(relayTwoPin, HIGH);
digitalWrite(relayThreePin, LOW);
return;
int toMinutes(int hours, int minutes)
int mins = (hours*minutesPerHour)+minutes;
return mins;
int ordinalDayOfYear(int year, int month, int day)
int ordinal = 0;
// Is it a leap year?
int leap = (year % 4 == 0) && (year % 100 != 0 || year % 400 == 0);
// Add up the days of the months preceding the current month
for (int i = 0; i < month - 1; i++)
ordinal += monthLen[i];
// Check for leap year
if (leap && month > 2)
ordinal++;
// Include days in current month
ordinal += day;
return ordinal;
int getAdjustedSunriseTime(int ordinalDay, time_t local)
// Get the sunrise time from the table - adjust index for zero-based array
int sunrise = pgm_read_word_near(sunriseAr + (ordinalDay - 1));
// Check for DST and adjust if necessary
if (myTZ.locIsDST(local))
// Add an hour to sunrise
sunrise += minutesPerHour;
// And finally add the sunrise opening delay
sunrise += SUNRISE_DELAY;
return sunrise;
int getAdjustedSunsetTime(int ordinalDay, time_t local)
// Get the sunset time from the table - adjust index for zero-based array
int sunset = pgm_read_word_near(sunsetAr + (ordinalDay - 1));
// Add an hour to sunset
sunset += minutesPerHour;
sunset += SUNSET_DELAY;
return sunset;
#ifdef DEBUG
//Function to print time with time zone
void printTime(time_t t, char *tz)
sPrintI00(hour(t));
sPrintDigits(minute(t));
sPrintDigits(second(t));
Serial.print(' ');
Serial.print(dayShortStr(weekday(t)));
Serial.print(' ');
sPrintI00(day(t));
Serial.print(' ');
Serial.print(monthShortStr(month(t)));
Serial.print(' ');
Serial.print(year(t));
Serial.print(' ');
Serial.print(tz);
Serial.println();
//delay(5000);
//Print an integer in "00" format (with leading zero).
//Input value assumed to be between 0 and 99.
void sPrintI00(int val)
if (val < 10) Serial.print('0');
Serial.print(val, DEC);
return;
//Print an integer in ":00" format (with leading zero).
void sPrintDigits(int val)
Serial.print(':');
if(val < 10) Serial.print('0');
#endif
ChickenDoor - V0.6
Saving Time.
// Includes
byte sekundy, minuty, hodiny, denVTydnu, denVmesici, mesic, rok; //global variables for time
//some chars for my use...you can add more
#define char_H 15
#define char_M 20
#define char_S 26
#define char_d 37
#define char_y 58
// Defines
#define DEBUG // zakomentovat PRO PROVOZ
#define OPEN 0
#define CLOSED 1
#define OFF 0
#define ON 1
#define SUNRISE_DELAY (30)
// Sunset times in seconds after midnight for each ordinal day of the year,
// eg, Jan 1 = array index 0, etc. The times are EST and are adjusted one
static const int sunsetAr[] PROGMEM = {964,
965,966,967,968,970,971,972,973,975,976,977,979,980,982,983,985,986,988,990,992,993,995,996,999,1001,1002,1004,1006,1008,1009,1010,1012,1014,1015,1017,1019,1021,1022,1024,1026,1028,1030,1031,1033,1035,1037,
1038,1040,1042,1044,1045,1047,1049,1051,1052,1054,1056,1058,1059,1061,1063,1065,1066,1068,1070,1071,1073,1075,1076,1078,1080,1081,1083,1085,1086,1088,1090,1091,1093,1095,1096,1098,1099,1101,1103,1104,1106,
1108,1109,1111,1112,1114,1116,1117,1119,1121,1122,1124,1125,1127,1129,1130,1132,1134,1135,1137,1138,1140,1142,1143,1145,1146,1148,1150,1151,1153,1154,1156,1158,1159,1161,1162,1164,1166,1167,1169,1170,1172,
1173,1175,1176,1178,1179,1181,1182,1184,1185,1186,1188,1189,1191,1192,1193,1194,1196,1197,1198,1199,1200,1202,1203,1204,1205,1206,1207,1208,1208,1209,1210,1211,1211,1212,1213,1213,1214,1214,1216,1216,1217,1217,
1217,1217,1217,1218,1218,1218,1218,1217,1217,1217,1217,1216,1215,1215,1214,1214,1213,1213,1212,1211,1211,1210,1209,1208,1207,1206,1205,1204,1203,1202,1201,1200,1198,1197,1196,1195,1194,1193,1191,1190,1188,1186,
1184,1182,1181,1179,1177,1176,1174,1172,1170,1168,1167,1165,1163,1161,1159,1157,1155,1153,1151,1149,1147,1145,1143,1141,1139,1137,1134,1132,1130,1128,1126,1124,1121,1119,1117,1115,1113,1110,1108,1106,1104,
1101,1099,1097,1095,1093,1090,1088,1086,1083,1081,1079,1077,1074,1072,1070,1068,1065,1063,1061,1059,1057,1054,1052,1050,1048,1046,1043,1041,1039,1037,1035,1033,1031,1028,1026,1024,1022,1020,1018,1016,1014,1012,
1010,1008,1006,1004,1003,1001,999,997,995,994,992,990,988,987,985,984,982,980,979,978,976,975,973,972,971,970,968,967,966,965,964,963,962,961,960,960,959,958,957,957,956,956,955,955,955,954,954,954,954,954,
954,954,954,954,954,954,955,955,956,956,957,957,958,959,959,960,961,962,963,964};
static const int sunriseAr[] PROGMEM = {481,481,481,481,481,480,480,480,479,479,478,478,477,476,476,475,474,473,472,471,470,469,468,467,466,464,463,462,460,459,458,456,455,453,452,450,445,447,445,443,442,
440,438,436,435,433,431,429,427,425,423,421,419,417,415,413,411,409,407,405,403,401,399,396,394,392,390,388,386,383,381,379,377,375,372,370,368,366,364,361,359,357,355,352,350,348,346,344,341,339,337,335,
332,330,328,326,324,321,319,317,315,313,311,309,306,304,302,300,298,296,294,292,290,288,286,284,282,280,278,277,275,273,271,269,268,266,264,262,261,259,258,256,254,253,251,250,249,247,246,245,243,242,241,
240,239,238,237,236,235,234,233,232,231,231,230,229,229,228,228,227,227,226,226,226,226,226,226,226,226,226,226,226,226,226,227,227,227,228,228,229,229,230,231,231,232,233,234,235,235,236,237,238,239,240,241,
243,244,245,246,247,249,250,251,252,254,255,256,258,259,261,262,263,265,266,268,269,271,272,274,275,277,278,280,281,283,284,286,287,289,290,292,294,295,297,298,300,301,303,304,306,307,309,310,312,314,315,
317,318,320,321,323,324,326,327,329,330,332,334,335,337,338,340,341,343,344,346,348,349,351,352,354,355,357,359,360,362,363,365,366,368,370,371,373,375,376,378,379,381,383,384,386,388,389,391,393,394,396,
398,399,401,403,405,406,408,410,411,413,415,417,418,420,422,423,425,427,429,430,432,434,435,437,439,440,442,443,445,447,448,450,451,453,454,456,457,458,460,461,462,464,465,466,467,468,469,470,471,472,473,474,
475,476,477,477,478,478,479,480,480,480,481,481,481,481,481,481,481};
// Constants
const int delayTime = 10000;
const int relayTwoPin = 2; // Door 1
const int relayThreePin = 3; // Door 2
const int secondsPerHour = 3600;
int sunset = 0;
int sunrise = 0;
int seconds = 0;
// Globals
// Timezone rules - US Eastern Time Zone (New York, Detroit)
//TimeChangeRule myDST = {"EDT", Second, Sun, Mar, 2, -240}; //Daylight time = UTC - 4 hours
//TimeChangeRule myEST = {"EST", First, Sun, Nov, 2, -300}; //Standard time = UTC - 5 hours
//Timezone myTZ(myDST, myEST);
// Central European Time (Frankfurt, Paris)
TimeChangeRule myDST = {"CEST", Last, Sun, Mar, 2, 120}; // Central European Summer Time
TimeChangeRule myEST = {"CET ", Last, Sun, Oct, 3, 60}; // Central European Standard Time
time_t utc, local;
// Init
sunset = 0;
sunrise = 0;
seconds = 0;
while (!Serial)
delay(200);
#ifdef DEBUG
else
#endif
utc = now();
// We have the date and time, convert it to seconds since midnight
seconds = toSeconds(hour(local), minute(local), 0);
if ((seconds > sunrise) && (seconds < sunset))
doorState = CLOSED;
openDoor();
doorState = OPEN;
closeDoor();
// Turn the lights on (6AM) or off (9PM)
initCoopLights(local);
//COMMUNICATION
//Wire.begin(); //start I2C communication
Serial.println(F(""));
Serial.println(F("H = hour, M = minute,y = year, m = month, d = day "));
Serial.println(F("H20 M07 y20 m04 d01 = 20:07 1.4.2020"));
Serial.println(F("Aktualni cas a datum v RTC modulu"));
vypis();
SerialComm();
tmElements_t tm;
RTC.read(tm);
sunset = 0;
sunrise = 0;
seconds = 0;
delay(delayTime);
utc = now();
openDoor();
closeDoor();
setCoopLights(local);
#ifdef DEBUG
Serial.print("seconds=");
Serial.print(seconds);
Serial.print(" - sunrise=");
Serial.print(sunrise);
Serial.print(" - sunset=");
Serial.print(sunset);
Serial.println("");
#endif
void openDoor()
#ifdef DEBUG
Serial.print("-----> Opening door: ");
utc = now();
#endif
doorState = OPEN;
// open the door
return;
void closeDoor()
#ifdef DEBUG
Serial.print("-----> Closing door: ");
utc = now();
#endif
doorState = CLOSED;
// close the door
return;
void initCoopLights(time_t t)
int curHour = hour(t);
int curDen = day(t);
int curMesic = month(t);
// Rosvitit po zapadu slunce do 20h ve dnech 5.10. do cca 15.3. pokud jsou zavrena dvirka
if (seconds > sunset-60 && curHour < 21 && (curMesic *100 + curDen >= 1005 || curMesic *100 + curDen <= 315) )
// Turn on the lights
lightState = ON;
#ifdef DEBUG
Serial.print("-----> Turning lights on: ");
utc = now();
#endif
digitalWrite(relayFourPin, LOW);
// Turn off the lights
lightState = OFF;
#ifdef DEBUG
Serial.print("-----> Turning lights off: ");
utc = now();
#endif
digitalWrite(relayFourPin, HIGH);
return;
void setCoopLights(time_t t)
if (lightState == OFF)
#ifdef DEBUG
Serial.print("-----> Turning lights on at ");
Serial.println(curHour);
#endif
lightState = ON;
if (lightState == ON)
lightState = OFF;
#ifdef DEBUG
Serial.print("-----> Turning lights off at ");
#endif
return;
int toSeconds(int hours, int minutes, int seconds)
int secs = (hours*60)+(minutes);
return secs;
int ordinal = 0;
ordinal++;
ordinal += day;
return ordinal;
sunrise += 60;
return sunrise;
sunset += 60;
return sunset;
sPrintI00(hour(t));
Serial.print(' ');
Serial.print(' ');
sPrintI00(day(t));
Serial.print(' ');
Serial.print(' ');
Serial.print(' ');
Serial.print(tz);
Serial.println();
return;
Serial.print(':');
//serial communication with PC
void SerialComm() {
tmElements_t tm;
//first char - data type
//sekundy and third char - data value
//there are used only "printable" characters
if (Serial.available() > 0) {
byte receivedCommand;
receivedCommand = Serial.read(); //read first char
delay(10); //wait for other char
byte receivedDataTens;
receivedDataTens = Serial.read();
receivedDataTens -= 48; // ASCII code for "0" is 48
byte receivedDataOnes;
receivedDataOnes = Serial.read();
receivedDataOnes -= 48; // ASCII code for "0" is 48
byte receivedData;
receivedData = (receivedDataTens * 10) + receivedDataOnes;
if (receivedData > 99) {
//maximal value is 99
receivedData = 0; //value is out of range
switch (receivedCommand) {
case 72:
//hodiny 72 = H
if (receivedData > 23) {
receivedData = 23;
tm.Hour = receivedData;
RTC.write(tm);
vypis();
case 77:
//minuty 77 = M
if (receivedData > 59) {
receivedData = 59;
tm.Minute = receivedData;
RTC.write(tm);
vypis();
case 83:
//sekundy 83 = S
receivedData = 59;
tm.Second = receivedData;
RTC.write(tm);
vypis();
case 100:
//denVmesici 100 = d
if (receivedData > 31) {
receivedData = 1;
tm.Day = receivedData;
RTC.write(tm);
vypis();
case 109:
//mesic 109 = m
if (receivedData > 12) {
receivedData = 1;
tm.Month = receivedData;
RTC.write(tm);
vypis();
case 121:
//rok 121 = y
tm.Year = receivedData + 2000;
RTC.write(tm);
vypis();
case 63:
//get data ? = 63
Serial.println(F("H = hodiny, M = minuty,y = rok, m = mesic, d = day "));
//flush serial data
Serial.flush();
void vypis() {
tmElements_t tm;
if (RTC.read(tm)) {
Serial.print("Ok, GMT Time = ");
print2digits(tm.Hour);
Serial.write(':');
print2digits(tm.Minute);
Serial.write(':');
print2digits(tm.Second);
Serial.print(", Date (D/M/Y) = ");
Serial.print(tm.Day);
Serial.write('/');
Serial.print(tm.Month);
Serial.write('/');
Serial.print(tmYearToCalendar(tm.Year));
Serial.println();
if (RTC.chipPresent()) {
Serial.println("The DS1307 is stopped. Please run the SetTime");
Serial.println("example to initialize the time and begin running.");
Serial.println();
Serial.println("DS1307 read error! Please check the circuitry.");
Serial.println();
void print2digits(int number) {
if (number >= 0 && number < 10) {
Serial.write('0');
Serial.print(number);
systemState = 0;
delay (1000); // měření po 1 sec
photocellVal = analogRead(photocellPin); // read inputs
if (photocellVal > daythreshold)
daylight = true;
if (photocellVal < darkthreshold)
daylight = false;
topSwitchState = digitalRead(topSwitchPin);
bottomSwitchState = digitalRead(bottomSwitchPin);
// read system status
if (daylight == true && topSwitchState == true)
systemState = 0; // motor stoji
if (daylight == true && topSwitchState == false)
systemState = 1; // dvere se oteviraji
if (daylight == false && bottomSwitchState == true)
if (daylight == false && bottomSwitchState == false)
systemState = 2; // dvere se zaviraji
DispVals();
switch (systemState) {
case 0: // motor stoji
digitalWrite(CloseDoorPin, LOW);
digitalWrite(OpenDoorPin, LOW);
analogWrite(EnMotorPin, 0);
case 1: // dvere se oteviraji
digitalWrite(OpenDoorPin, HIGH);
analogWrite(EnMotorPin, SPEED);
case 2: // dvere se zaviraji
digitalWrite(CloseDoorPin, HIGH);
default:
}Kód: Vybrat vše
#define light 11 //vystup pro zarovku
#define rele_open 12 //vystup pro rele otevrit
#define rele_close 13 //vystup pro rele zavrit
#define light_sens A0 //analog pro pripojeni senzoru svetla
#define time_light 13 // hodiny - cas konce doby sviceni od svitani
#define ladeni 0 // 0 - ladeni 1 - bez vystupu na Seriovy port
#if (ladeni)
#define cyklus 5 // sekundy - cyklus mereni pro ladeni
#else
#define cyklus 15 // sekundy - jak casto probehne task mereni
#endif
// *********************** nize uz nic nemenit *****************************************
int is,im,ih,id,ida; // variables for time
float time,s1,m1,h1,d1, light2; // Set up variables to calculate time
bool state = false, casujeme = false;
unsigned long aktualniMillis, predchoziMillis; //casy pro 15s task mereni
unsigned long ranoMillis; //ulozeny cas pri vychodu slunce pro casovani 13h
const unsigned long SECOND = 1000;
#if (ladeni)
const unsigned long HOUR = 60000; //ladeni = napevno 1 minuta misto hodiny
#else
const unsigned long HOUR = 3600*SECOND;
#endif
void setup(){
pinMode (light_sens, INPUT);
pinMode (light, OUTPUT);
pinMode (rele_open, OUTPUT);
pinMode (rele_close, OUTPUT);
predchoziMillis = millis(); //cas startu arduina
void loop(){
aktualniMillis = millis(); //aktualni cas behu arduina
if(aktualniMillis - predchoziMillis > cyklus * 1000) { //task probihajici jednou za XXs
predchoziMillis = aktualniMillis; //nulovani XXs citace
if(ladeni) Serial.println(analogRead(light_sens)); //namerena hodnota senzoru
if(ladeni) Serial.println(state); //aktualni stav
if(analogRead(light_sens) >= 550 && state == false){ //uz je svetlo a state = FALSE
state = true;
digitalWrite(rele_close, LOW);
digitalWrite(rele_open, HIGH); //otevrit dvirka
ranoMillis = millis(); //zacatek casu pro 13h
casujeme = true;
if(ladeni) Serial.println("Otevrit");
if(analogRead(light_sens) <= 200 && state == true){ //podminka pro rozsviceni
digitalWrite(light, HIGH); //rozsvitit
if(ladeni) Serial.println("Rozsvitit");
if(analogRead(light_sens) <= 100 && state == true){ //podminka pro zavreni dvirek
state = false;
digitalWrite(rele_open, LOW);
digitalWrite(rele_close, HIGH); //zavrit dvirka
if(ladeni) Serial.println("Zavrit");
//zhasnout za X hodin
if(aktualniMillis - ranoMillis > time_light * HOUR && casujeme == true) {
digitalWrite(light, LOW);
casujeme = false;
if(ladeni) Serial.println("Zhasnout");
} //konec tasku po 15s
} //konec LOOP
Když bude problém, příští týden to sfouknem s dětmi na kroužku, teď jsem zasekanej.
const long eventTime_1_LDR = 20000; // 20 vteřin
unsigned long previousTime_1 = 0;
int photocellVal; // analog reading of the photocel
bool daylight = true; // daylight status
int darkthreshold = 20;
int daythreshold = 350;
int systemState = 0;
int SPEED = 220;
int bottomSwitchPin = 2; // Reed switches top and bottom of coop door
int topSwitchPin = 4;
bool topSwitchState; // true if door is up
bool bottomSwitchState; // true if door is down
pinMode(bottomSwitchPin, INPUT);
pinMode(topSwitchPin, INPUT);
pinMode(EnMotorPin, OUTPUT);
pinMode(CloseDoorPin, OUTPUT);
pinMode(OpenDoorPin, OUTPUT);
systemState = 0;
unsigned long currentTime = millis();
if ( currentTime - previousTime_1 >= eventTime_1_LDR) {
previousTime_1 = currentTime;
daylight = true;
