Posunutí o jedno místo v paměti
Re: Posunutí o jedno místo v paměti
Příspěvek od ondraN » 18 úno 2021, 06:43
Zkus tenhle upravený kód.
#include <SPI.h>
#define csPIN 10
#define posPIN 9
#define negPIN 8
#define WREN  6
#define WRDI  4
#define RDSR  5
#define WRSR  1
#define READ  3
#define WRITE 2
#define EEPROMSIZE 512
int8_t intValueOfHexaKey(char c)
  if ((c >= '0') && (c <= '9')) return c - '0';
  if ((c >= 'A') && (c <= 'F')) return c - 'A' + 10;
  return -1;
uint8_t readByteAt(uint8_t cs, uint16_t adr)
  SPI.beginTransaction(SPISettings(20000000, MSBFIRST, SPI_MODE0));
  digitalWrite(cs, LOW);
  uint8_t b = highByte(adr);
  b = b << 3;
  b = b | READ;
  SPI.transfer(b);
  SPI.transfer(lowByte(adr));
  b = SPI.transfer(0);
  digitalWrite(cs, HIGH);
  SPI.endTransaction();
  return b;
//end
uint8_t writeByteAt(uint8_t cs, uint16_t adr, char d)
  SPI.transfer(WREN);
  delay(10);
  uint8_t a = highByte(adr);
  a = a << 3;
  a = a | WRITE;
  SPI.transfer(a);
  a = SPI.transfer(d);
  delay(15);
  return a;
//end
//setup
  digitalWrite(csPIN, HIGH);
  pinMode(csPIN, OUTPUT);
  pinMode(posPIN, OUTPUT);
  digitalWrite(posPIN, HIGH);
  pinMode(negPIN, OUTPUT);
  digitalWrite(negPIN, LOW);
  SPI.begin();
  Serial.setTimeout(7000);
//main loop
  if (Serial.available() > 0)
    char command = Serial.read();
    if (command == '1')
      digitalWrite(posPIN, LOW);
      digitalWrite(negPIN, HIGH);
      delay(20);
      char ch[30];
      for (uint16_t i = 0; i < EEPROMSIZE; i++)
        sprintf(ch, "%02X", readByteAt(csPIN, i));
        Serial.print(ch);
    else if (command == '2')
      delay(5);
      while(Serial.available() > 0){
      	Serial.read();
      delay(50);
      char dump[EEPROMSIZE];
      char readData[EEPROMSIZE * 2];
      Serial.readBytes(readData, EEPROMSIZE * 2);
      for (int i = 0; i < EEPROMSIZE; i++)
        dump[i] = intValueOfHexaKey(readData[i*2+1]) + 16 * intValueOfHexaKey(readData[i*2]);
        Serial.print(dump[i]);
      char ch[30];
        sprintf(ch,"%02X",writeByteAt(csPIN,i,dump[i]));
      delay(500);
  delay(10);
mourison
Příspěvek od mourison » 18 úno 2021, 12:28
Ahoj funguje skvěle.
Kdyžtak mi hoď učet do PM, pošlu ti tam nějakou malou uplatu, moc mi to pomohlo. ;)
Příspěvek od ondraN » 18 úno 2021, 14:02
Nic za to nechci. A přišel jsi na to, v čem byl ten problém a proč to teď funguje :?: :mrgreen:
Z toho je vidět, že když potřebuješ pomoc, tak to sem musíš dát všechno a podrobně to popsat, protože chyba byla úplně jinde než v zápisu nebo čtení z paměti.
mourison
Příspěvek od mourison » 18 úno 2021, 18:01
No v podstatě po zadání 2ky to tedka čeká na zadání HEXU, předtím se to pustilo rovnou, ale furt nechápu proč o jedno místo :D
Příspěvek od ondraN » 18 úno 2021, 19:33
Je to tak, že když jsi zadal číslo, tak terminál za něj doplnil znak new line '\n'. Ten zůstal v bufferu. Funkce převodu z textového Hex vrátila spávně hodnotu -1, ale protože nikde nekontroluješ, jestli nevrací chybovou hodnotu, tak jsi ji klidně zpracoval a z toho vzniklo to F. Takže příště, čistit buffery a hlídat chybové stavy :!: :mrgreen:
mourison
Příspěvek od mourison » 18 úno 2021, 20:41
Aha vidíš, to je super, já vůbec nevěděl, že doplní znak /n automaticky :/
Je to protože já zadal 2 a hned za to HEX ?
Kdežto ted zadám 2, a začne to čekat znova tudíž je to bez toho /n ?
