Victron Energy solar a vyčtení hodnot
Kony
Příspěvek od Kony » 07 bře 2022, 08:54
Ahoj, nezkoušel někdo propojit a vyčítat hodnoty z controleru Victron Energy solar do Arduina ?
Dle tohoto videa by to mělo jít
https://www.youtube.com/watch?v=w-9kYkSuCwc
Je tam i knihovna, která by měla podporovat komunikaci
https://community.victronenergy.com/que ... r-ard.html
Kony
Re: Victron Energy solar a vyčtení hodnot
Příspěvek od Kony » 07 bře 2022, 18:54
Tak jsem zjistil ze ten kod co jsem posilal je pro AVR architekturu...
Ale nasel jsem i pro ESP8266 https://github.com/physee/Victron.Arduino-ESP8266
ale stale se nemuzu pohnout
    A:Pim Rutgers
    E:pim@physee.eu
    Code to grab data from the VE.Direct-Protocol on Arduino / ESP8266.
    Tested on NodeMCU v1.0
    The fields of the serial commands are configured in "config.h"
#include <SoftwareSerial.h>
#include "config.h"
// Serial variables
#define rxPin D7
#define txPin D8                                    // TX Not used
SoftwareSerial victronSerial(rxPin, txPin);         // RX, TX Using Software Serial so we can use the hardware serial to check the ouput
                                                    // via the USB serial provided by the NodeMCU.
char receivedChars[buffsize];                       // an array to store the received data
char tempChars[buffsize];                           // an array to manipulate the received data
char recv_label[num_keywords][label_bytes]  = {0};  // {0} tells the compiler to initalize it with 0.
char recv_value[num_keywords][value_bytes]  = {0};  // That does not mean it is filled with 0's
char value[num_keywords][value_bytes]       = {0};  // The array that holds the verified data
static byte blockindex = 0;
bool new_data = false;
bool blockend = false;
    // Open serial communications and wait for port to open:
    victronSerial.begin(19200);
    // Receive information on Serial from MPPT
    RecvWithEndMarker();
    HandleNewData();
    // Just print the values every second,
    // Add your own code here to use the data.
    // Make sure to not used delay(X)s of bigger than 50ms,
    // so make use of the same principle used in PrintEverySecond()
    // or use some sort of Alarm/Timer Library
    PrintEverySecond();
// Serial Handling
// This block handles the serial reception of the data in a
// non blocking way. It checks the Serial line for characters and
// parses them in fields. If a block of data is send, which always ends
// with "Checksum" field, the whole block is checked and if deemed correct
// copied to the 'value' array.
void RecvWithEndMarker() {
    static byte ndx = 0;
    char endMarker = '\n';
    char rc;
    while (victronSerial.available() > 0 && new_data == false) {
        rc = victronSerial.read();
        if (rc != endMarker) {
            receivedChars[ndx] = rc;
            ndx++;
            if (ndx >= buffsize) {
                ndx = buffsize - 1;
        else {
            receivedChars[ndx] = '\0'; // terminate the string
            ndx = 0;
            new_data = true;
        yield();
void HandleNewData() {
    // We have gotten a field of data
    if (new_data == true) {
        //Copy it to the temp array because parseData will alter it.
        strcpy(tempChars, receivedChars);
        ParseData();
        new_data = false;
void ParseData() {
    char * strtokIndx; // this is used by strtok() as an index
    strtokIndx = strtok(tempChars,"\t");      // get the first part - the label
    // The last field of a block is always the Checksum
    if (strcmp(strtokIndx, "Checksum") == 0) {
        blockend = true;
    strcpy(recv_label[blockindex], strtokIndx); // copy it to label
    // Now get the value
    strtokIndx = strtok(NULL, "\r");    // This continues where the previous call left off until '/r'.
    if (strtokIndx != NULL) {           // We need to check here if we don't receive NULL.
        strcpy(recv_value[blockindex], strtokIndx);
    blockindex++;
    if (blockend) {
        // We got a whole block into the received data.
        // Check if the data received is not corrupted.
        // Sum off all received bytes should be 0;
        byte checksum = 0;
        for (int x = 0; x < blockindex; x++) {
            // Loop over the labels and value gotten and add them.
            // Using a byte so the the % 256 is integrated.
            char *v = recv_value[x];
            char *l = recv_label[x];
            while (*v) {
                checksum += *v;
                v++;
            while (*l) {
                checksum+= *l;
                l++;
            // Because we strip the new line(10), the carriage return(13) and
            // the horizontal tab(9) we add them here again.
            checksum += 32;
        // Checksum should be 0, so if !0 we have correct data.
        if (!checksum) {
            // Since we are getting blocks that are part of a
            // keyword chain, but are not certain where it starts
            // we look for the corresponding label. This loop has a trick
            // that will start searching for the next label at the start of the last
            // hit, which should optimize it.
            int start = 0;
            for (int i = 0; i < blockindex; i++) {
              for (int j = start; (j - start) < num_keywords; j++) {
                if (strcmp(recv_label[i], keywords[j % num_keywords]) == 0) {
                  // found the label, copy it to the value array
                  strcpy(value[j], recv_value[i]);
                  start = (j + 1) % num_keywords; // start searching the next one at this hit +1
                  break;
        // Reset the block index, and make sure we clear blockend.
        blockindex = 0;
        blockend = false;
void PrintEverySecond() {
    static unsigned long prev_millis;
    if (millis() - prev_millis > 1000) {
        PrintValues();
        prev_millis = millis();
void PrintValues() {
    for (int i = 0; i < num_keywords; i++){
        Serial.print(keywords[i]);
        Serial.print(",");
        Serial.println(value[i]);
a stále chyby :
In file included from C:\ARDUINO\Zahrada\sketch_mar07a\sketch_mar07a.ino:10:
config.h:554:75: error: extended character ↵ is not valid in an identifier
  554 |       <span aria-hidden="true" class="d-inline-block ml-1 v-align-middle">↵</span>
config.h:559:56: error: extended character ↵ is not valid in an identifier
  559 |       <span class="d-inline-block ml-1 v-align-middle">↵</span>
config.h:601:75: error: extended character ↵ is not valid in an identifier
  601 |       <span aria-hidden="true" class="d-inline-block ml-1 v-align-middle">↵</span>
config.h:606:56: error: extended character ↵ is not valid in an identifier
  606 |       <span class="d-inline-block ml-1 v-align-middle">↵</span>
config.h:639:75: error: extended character ↵ is not valid in an identifier
  639 |       <span aria-hidden="true" class="d-inline-block ml-1 v-align-middle">↵</span>
config.h:644:56: error: extended character ↵ is not valid in an identifier
  644 |       <span class="d-inline-block ml-1 v-align-middle">↵</span>
config.h:677:75: error: extended character ↵ is not valid in an identifier
  677 |       <span aria-hidden="true" class="d-inline-block ml-1 v-align-middle">↵</span>
config.h:682:56: error: extended character ↵ is not valid in an identifier
  682 |       <span class="d-inline-block ml-1 v-align-middle">↵</span>
config.h:2158:9: error: extended character ’ is not valid in an identifier
 2158 |     You can’t perform that action at this time.
exit status 1
tak tady dalsi kod :
https://github.com/jorge5a/VictronESP
Příspěvek od jankop » 07 bře 2022, 22:26
Tím, že budeš zkoušet další a další kódy, se asi nikam nedostaneš. Snaž se alespoň něco pochopit. V tom posledním programu zkus odstranit v config.h ty entry, který ti dávaj chybový hlášky. Nediv se, že při tvém přístupu se nikdo do rad nehrne. Ty čekáš, že prostě přijde něco hotového, ale to se stává naprosto vyjímečně.
Kony
Příspěvek od Kony » 07 bře 2022, 22:35
Snazim se to pochopit.. snazim se odstranovat...
sedim u toho jiz nekolik hodin
Příspěvek od jankop » 08 bře 2022, 08:00
Dělal jsem něco podobného, ale pro AXPERT a psal jsem to v Lua. Teď to mám z části hotový pro ESP8266 Arduino.
Kony
Příspěvek od Kony » 08 bře 2022, 08:13
A mohl by ses prosim podelit o example ?
Příspěvek od jankop » 08 bře 2022, 08:51
Vem si tohle, co už máš
Spusť na tom Arduino IDE. Musíš však přidat soubor config.h do projektového adresáře k souboru SerialRead.ino
Pak se to bez chyb a problémů přeloží. Pochopitelně musíš nastavit odpovídající desku. Pokud budeš mít nějaký další problém, dej vědět. Jestli je ovšem program opravdu funkční s Victronem netuším. Taky nevím, s jakými úrovněmi napětí Victron na RS232 pracuje, na to pozor. A ještě bys v tom souboru config.h měl tuším definovat správný model toho Victronu. Teď je #define MPPT_75_10
Takhle vypadá webový interface toho mého programu pro Axpert.
Kony
Příspěvek od Kony » 08 bře 2022, 20:38
Povedlo se mi to tam nahrat, ale jak uklozit do promene jen urcitou hodnotu ?? Nyni je tam vse... a vypisuje se vse naraz... potrebuji vypsat jen aktualni vyrobu ve W ze solaru, potom do druhe promenne aktualni odber z baterek.
Příspěvek od jankop » 09 bře 2022, 14:13
1. Jaký model Victronu máš?
2. Jak se jmenují ty dva parametry, které tě zajímají, podle souboru config.h ?
Stačí ti je samostatně vypsat, nebo s nimi chceš v programu dál pracovat?
Měla by to být brnkačka.
Kony
Příspěvek od Kony » 09 bře 2022, 15:29
Chci prave s nima dale pracovat... takze aby byla kazda hodnota v samotne promenne
